20 Most Recent Learning Curve Toys Thomas and Friends Wooden Railway Battery Powered Jet Engine With Thomas Questions & Answers
there maybe a switch underneath, try checking it out. hope this helps
Learning Curve... | Answered on Feb 04, 2010
Hi Joanmsynonds,
There has to be some socket for changing your toy, if in case it has in-built battery.
It may take power while running in the track from the track itself.. Check for how it is designed.
If there exists an in-built battery for your device, then obviously it should be rechargeable only. In case of doubt, visit your nearest toy shop and ind similar model as yours, and study it.
I hope this is useful to you
Thanks
Learning Curve... | Answered on Jul 03, 2010
Put the crank handle in the down position and then use the arrows on the gears to guide you. The two gears that hold the two spirals should be closest to you. Make the two arrows on the gears point directly at each other(keeping the crank in the down position). The third gear's arrow (furthest from you) should point directly at you bisecting an imaginary line formed by the other two arrows pointing at each other. The idea is to get the spirals lined up so they create a channel for a ball to fit in.
Toys | Answered on Oct 04, 2020
https://directbrown.weebly.com/dreamsky-alarm-clock-radio-user-manual-ds201.html#dreamsky-alarm-clock-radio-user-manual-ds201
Toys | Answered on Sep 29, 2020
Maybe you can search on Amazon or Ebay. This manual is cetainly on sale.
Toys | Answered on Aug 28, 2020
I found this on a review of the dog:
Playing with Lucky is pretty simple but does require some learning. Lucky is programmed to respond to 15 different commands but the commands must be issued the same way each time. First, you say Lucky's name to engage him. Once you say "Lucky" (or whatever name you give him) he will then respond to you with 2 barks. After he goes ruff-ruff, then you can tell him what to do. The commands are as follows:
Speak to Me - he will sit or stand & bark
Come Here - he will run forward and back
Pounce - he will crouch and pounce excitedly
Lay down - he will lay down on his tummy
Sit - he sits
Want a Treat? - he stands and barks (begs)
On your head - He does a headstand
Go to sleep - lays down, snores and enters sleep mode
Sing a song - he'll bark one of 2 songs
Good Dog - acts excited by shuffling his feet
Bad Dog - he crouches down
Put 'em up - he'll stand up on his hind legs. Then when you say "bang bang" he plays falls down and plays dead.
Tug of War - he opens his mouth for you to put in his leash, he closes his mouth and tugs a little
Lucky also comes with a "sleep" mode and automatically shuts off after not being played with for 3 minutes.
Playing with Lucky is pretty simple, you command and Lucky performs. Well, Lucky performs most of the time. You need to be sure that he has your attention (barking twice) first before issuing the command. A few of the tricks are a bit more complicated - Put 'em up & Tug of War but the rest are very straight forward. I do notice that both my husband and I had the tendency to want to 'yell' or raise our voices when commanding Lucky - but that isn't necessary.
Toys | Answered on Aug 15, 2020
Helps to get back each and every inaccessible Outlook items such as emails, calendars, notes, tasks, journals, contacts, etc from Outlook personal folders and make them workable without loss any data. See at:- Outlook Emails Recovery
Toys | Answered on Jul 27, 2020
If the santa has no built in bluetooth or memory slot then the nest best thing is to place a bluetooth speaker inside the santa and then play songs.
Toys | Answered on Jul 15, 2020
I just bought these at a yard sale today. Did anyone find an answer to this or know what the name of the toy is? Manufacturer?
Toys | Answered on Jun 27, 2020
No, it is not possible. Since the records is with your bank - the other bank ATM will not accept this option. Therefore, you cannot use other bank ATM to change the pin. Even when you receive the debit card first time, you have to activate your card in the ATM of your bank only initially and not with another bank ATM
Learning Curve Toys Thomas and Friends Wooden Railway Battery Powered Jet Engine With Thomas Logo
Popular Tags
4 questions posted
Top Learning Curve Toys Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Learning Curve Toys Toy Expert? Answer questions, earn points and help others
View Most Popular
  • Learning Curve Toys Toys
Most Popular Question
thomas jet engine toy put new
  • Toys
