20 Most Recent
Whirlpool 8572546 Duet Sport Stacking Kit Questions & Answers
My duet sport combo shakes like crazy
Suspect your load of clothes is incorrect. Wash large & small items together. Large bath towels, or bath / toilet mats and trainers are notorious for becoming out of balance. As is a 'too small' load as well.
11/4/2013 10:50:35 PM •
Whirlpool...
Answered
on Nov 04, 2013
I can't get my whirlpool started?
You might have a problem with the door switch. Try to reset the unit by unplugging it for a couple of minutes. If that does not work then you need to see if the door switch is bad.
5/23/2013 4:32:50 PM •
Whirlpool...
Answered
on May 23, 2013
Whirlpool Sport Duet Dryer powers on but when you
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$#@#$
9/30/2010 6:28:52 AM •
Whirlpool...
Answered
on Sep 30, 2010
Hi i have a whirlpool duet sport front load wash
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
9/30/2010 5:51:28 AM •
Whirlpool...
Answered
on Sep 30, 2010
How to replace whirlpool washer Drum, baffle
Just order a new one from an online parts store and put it in. The new ones dont screw from behind. They just snap in. By the way, the rest of the baffles will break as well. So you may as well by a couple. But there not cheap-You can order them through Sears and pay 23.95 each.
3/16/2009 6:54:27 PM •
Whirlpool...
Answered
on Mar 16, 2009
