20 Most Recent Staples TXC122ACC Cross-Cut Shredder; 12 Sheet Questions & Answers
I need a plastic gear for the Staples SPL-TXC122A Does anyone have one?
Staples... • Answered on Nov 22, 2016
Maybe the calculator could be broken then or the battery is low if it takes batteries.
Staples Office... • Answered on Jan 31, 2021
I don't think taking it apart will help - when staples don't bend behind the papers, assuming the correct staples are used, it is usually either the anvil is worn or there is some misalignment between the staple and the anvil. The anvil is usually the part that wears out first, fortunately many office staplers use a dual anvil that can be turned around to select the staples being bent outwards. This position is ideal when the staple will need to be removed at a later date. Staples are usually produced with a sharp square end to each leg that after a few thousand staples will have done some damage to the anvil or a few hundred if the anvil had slipped through unhardened. I suggest you take a look under strong light and magnification and compare it with that of a working stapler...
Staples Office... • Answered on Nov 20, 2020
IF YOU LOOK INTO THE SLOT WHERE YOU FEED THE PAPER...GET A FLASHLIGHT ........IN THE MIDDLE OF THE SLOT YOU WILL SEE A TINY SWITCH. THAT THING SOMETIMES GETS GUMMED UP WITH GLUE FROM ENVELOPES AND SUCH... TRY SOME WD-40 ON THAT SWITCH... WITH THE MACHINE UNPLUGGED PUT PAPER IN THE SLOT TO MOVE THE SWITCH SO THE WD-40 CAN LOOSEN UP ANYTHING .... THEN TRY BLOWING AIR IN IT.... ARE YOU SURE THAT THE TOP OF THE SHREDDER IS SITTING FLUSH WITH THE PORTION IT RESTS ON??? THAT COULD ALSO MAKE IT NOT WORK..... OR IF THE BASKET NEEDS EMPTYING THE TOP WONT REST FLUSH ON THE BASKET.
Staples Office... • Answered on Feb 18, 2020
Usual cause is paper jammed in the cutting heads.
Staples Office... • Answered on Sep 17, 2019
Staples TXC122ACC Cross-Cut Shredder; 12 Sheet Logo
11 questions posted
Top Staples Office Equipment & Supplies Experts
John mullen
gbob59
Vernon Taylor
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Staples Office Equipment & Supplies
Most Popular Question
parts manual spl txc122a
  • Office Equipment & Supplies
