20 Most Recent AT&T 972 Two-Line Memory phone Questions & Answers
0answers
manual
Ringer turned off. how do you turn it back on
Press either line 1 or line 2 on the face of the phone then slide the volume button up or down, for example, press line 1 and slide volume up to turn on ringer, and press line 2 and slide down to turn ringer off
3/13/2013 5:10:57 PM • AT&T 972... • Answered on Mar 13, 2013
Need power suppy cord for AT&T Caller ID Telephone 972
duplicate
2/23/2013 4:25:30 AM • AT&T 972... • Answered on Feb 23, 2013
0answers
L1 & L2 ringer off.
Select which ever line you want turned on then keep pressing the volume up button until ringer off displays goes away.
8/24/2011 5:34:43 PM • AT&T 972... • Answered on Aug 24, 2011
0answers
I need a power adapter
9V - 780mA
1/5/2011 8:03:52 PM • AT&T 972... • Answered on Jan 05, 2011
Speaker phone doesn't work
try to press the speaker phone after u get the dial tone...or change the batteries
12/16/2010 2:17:53 PM • AT&T 972... • Answered on Dec 16, 2010
I have the ATT 973 2-line speakerphone.
I use the 974 4 line version in my office so the buttons may not be exactly the same but press ENTER then toggle to PHONE SETTINGS & press ENTER. Toggle to RINGER ON/OFF & press ENTER. You should see L1 in the window and the ringer may be set OFF, toggle to ON then press ENTER. Toggle to L2 and repeat the process.
You have to do this on each phone.
4/17/2010 4:04:39 PM • AT&T 972... • Answered on Apr 17, 2010
3answers
AT&T Model#972 How to lower ringer volume?
Hey how are you ??? sorry I didnt see your post til today I'm supridse no other experts didnt reply to it :(
Any way here is your user manual
http://qwest.ettp.net/reference/ATT%20Model%20972%20Manual.pdf
and to solve your problem
When not on an a
call press a LINE
button, then press
VOLUME + to
increase,VOLUME
- to decrease
volume of the
ringer for that line.
View manual for details.,,,
And again I apoligise for the late reply Sir ,, I do hope all is well with you .. Regards
1/12/2008 10:48:57 PM • AT&T 972... • Answered on Jan 12, 2008
How to register AT&T Synj SB67108 to new base unit SB67138?
Register SynJ SB67108 Handset How to register AT&T Synj SB67108 to new base unit SB67138? To register an AT&T SynJ SB67108 handset to a new SB67138 base unit, you will need to follow these steps:
  1. Make sure the new base unit is plugged in and turned on.
  2. Press and hold the "Menu" button on the handset until the display shows "Menu."
  3. Use the navigation buttons to select "Registration" and press "Select."
  4. Select "Base" and press "Select."
  5. The handset will begin searching for the new base unit.
  6. Once the base unit is found, it will be displayed on the handset's screen.
  7. Select the new base unit and press "Select" to complete the registration process.
  8. The handset should now be registered with the new base unit.
Note: if you have multiple handset you need to register, repeat step 2-7 with each handset.
1/22/2023 6:32:18 AM • AT&T Lands... • Answered on Jan 22, 2023
How do I deregister my AT&T CL82313 handset please?
Question edited got clarity. Video should help, similar model. https://www.google.com/search?q=deregister+my+at%26t+cl82313+handset ..
6/28/2022 4:54:29 PM • AT&T Lands... • Answered on Jun 28, 2022
Where can I get a replacement power cord for a handset dock for an AT&T phone model : TL96217
Try AT&T direct https://telephones.att.com/shop The second link might work, but it is a $28 gamble. The first link says specifically that it isn't for the handsets, but doesn't show the end connector! https://www.google.com/search?q=AT%26T+TL96217%2C+replacement+power+cord+for+a+handset+dock ..
1/14/2022 11:55:24 PM • AT&T Lands... • Answered on Jan 14, 2022
Standby mode At&t CL8`301
Do you mean the AT&T CL81301 Cordless telephone? This model doesn't have an answering system. You'd need to adjust the number of rings for your voicemail system through the telephone company's system. See the manual here: https://att.vtp-media.com/media/p/document2/products/%7B40A22BFC-681D-46DC-B836-7CB7C7A691FE%7D/CL81101_CIB_5_610.pdf . If you mean the AT&T CL82301 or the CL83301, first make sure that the system is set to Answer On. Do this with the base Answer On/Off button or through the Menu system (see below for accessing the Answering System menu). You'll need the Answer On/Off line in the handset menu. With the phone system idle (no calls in or out, no one using another handset), press Menu/Select. Use the Up(DIR)/Down(CID) arrows to navigate to Answering Sys. Press Menu/Select. Navigate to Ans Sys Setup and press Menu/Select. Navigate to # of Rings and press Menu/Select. Use the up/down arrows to choose the number of rings and press Menu/Select to Save. Press Off/Cancel to exit the menu system. The manual for this cordless telephone system is available at ManualsLib, https://www.manualslib.com/products/AtAndt-Cl82301-165464.html . See page 47 of the manual, https://www.manualslib.com/manual/643600/AtAndt-Cl82101.html?page=53#manual . Note: if you choose Toll Saver, the answering system will pick up after two rings if you have new messages. It will pick up after 4 rings if there are no new messages. I hope this helps. If you have a different AT&T CL8 * 301, please add a comment with the correct second digit in the model number. Cindy Wells
8/22/2021 9:58:57 PM • AT&T Lands... • Answered on Aug 22, 2021
AT&T 972 Two-Line Memory phone Logo
26 questions posted
Top AT&T Lands Phones Experts
Marvin
Marvin
Lawrence Oravetz
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
AT&T Lands Phones
  • AT&T Lands Phones
Most Popular Question
l1 amp l2 ringer off
  • Lands Phones
