20 Most Recent Gigaset As300 Twin Dect Cordless Phone - Black Questions & Answers
Phone not working
Hi Pam, Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit. 2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop. Rana.
12/29/2013 6:06:03 AM • Gigaset As300... • Answered on Dec 29, 2013
0answers
Phone
Be the first to answer 12/28/2013 6:55:57 PM • Gigaset As300... • Posted on Dec 28, 2013Be the first to answer
User manual of beetel cordless X78
See pages 26 and 27 of the manual ("Selecting a base station/Enrolling a handset") at https://www.manualslib.com/manual/1211269/Detewe-Beetel.html?page=29#manual You will need the "PARK" number on the bottom of the base unit, or, if there aren't any other base stations within range (~ 60-600 meters, depending on building environment), at least the last four digits of the PARK.
3/20/2023 2:21:14 PM • Lands Phones • Answered 21 hours ago
2answers
What phones can be used on a Prostar 824 system please?
Question edited for clarity and typo. No, only those phones, as they are part of a system. https://dcomcomputers.com/samsung-prostar-824-black-digital-phone/ ..
3/18/2023 7:13:12 PM • Lands Phones • Answered 2 days ago
More rings required on BT FREESTYLE 750 before ans phone cuts in
The instructions say you change them using the answer phone menu in the base - you need to scroll to 'answer delay' and you can increase the rings to a maximum of 8
3/9/2023 10:04:27 PM • Lands Phones • Answered on Mar 09, 2023
Why is the caller ID not displayed?
Contact your telco. It is a feature supplied by them.
3/1/2023 8:46:02 PM • Lands Phones • Answered on Mar 01, 2023
Lost ortho allclear cordless power mister charging cord and need to replace it..what size is the cord?
The Ortho AllClear Cordless Power Mister charging cord requires a 5V DC power supply with a micro USB connector. You can purchase a replacement cord with these specifications at most electronics stores or online retailers. Make sure to verify that the voltage and connector type match the specifications of your device before purchasing a replacement cord.
2/26/2023 2:58:01 PM • Lands Phones • Answered on Feb 26, 2023
HOw to retreive messages from RCA Telefield model 1000
To retrieve messages from the RCA Telefield model 1000 answering machine, follow these steps:
  1. Press the "play" button on the answering machine. You will hear a beep and the machine will start playing your messages.
  2. Use the "skip" and "repeat" buttons to navigate through your messages.
  3. To save a message, press the "save" button. To delete a message, press the "delete" button.
  4. If you want to keep a message, write down the date and time of the message and the caller's phone number.
If you are having trouble retrieving messages or the answering machine is not working properly, you may need to reset it. To reset the RCA Telefield model 1000 answering machine, unplug it from the power source for a few minutes and then plug it back in. This should reset the answering machine and clear any issues.
2/26/2023 10:27:31 AM • Lands Phones • Answered on Feb 26, 2023
My NEC-SL1000 all locals no dial tone and only blue steady solid light appears.what should be the problem
A steady blue light on your NEC-SL1000 system usually indicates that the system is in standby mode. However, the lack of a dial tone on all local lines indicates a problem with the system or phone lines. Here are a few steps you can try to troubleshoot the issue:
  1. Check the phone lines: Make sure that all phone lines connected to the system are properly connected and not damaged. If you have multiple lines, test each one individually to determine which line is causing the issue.
  2. Restart the system: Turn off the system and unplug it from the power source. Wait for at least 10 seconds before plugging it back in and turning it on again.
  3. Reset the system: If restarting the system doesn't work, you may need to perform a system reset. Refer to your user manual for specific instructions on how to reset your NEC-SL1000.
  4. Contact a professional: If none of the above steps work, you may need to contact a professional NEC-SL1000 technician to diagnose and fix the issue.
It's also possible that the steady blue light is indicating a different issue altogether. Again, refer to your user manual or contact a professional for further assistance.
2/26/2023 5:16:30 AM • Lands Phones • Answered on Feb 26, 2023
Panaphone kx-T2838LM
Tengo telefono Panaphone kxt-2838LM, antiguo, agotado, pero muy bueno en su funci?n. Perd? manual de instrucciones de uso. Podr?a env?armelo por Gmail: gracias [email protected]
2/25/2023 6:21:28 PM • Lands Phones • Answered on Feb 25, 2023
How can I use my B&O phones as intercom only? I have done this successfully, but I have a constant alert: no dial tone on both phones. Can I remove this alert?
If you want to use your Bang & Olufsen (B&O) headphones as an intercom only, without any phone-related functionality, you can try the following steps to remove the "no dial tone" alert:
  1. Disable the Bluetooth and/or cellular data connections on your B&O headphones and/or mobile device, if applicable.
  2. Check the user manual or settings menu of your B&O headphones to see if there is an option to disable or customize alerts or notifications. If so, try to find and disable the "no dial tone" alert or any other phone-related alerts.
  3. If you cannot find an option to disable or customize the alert on your B&O headphones, you may need to use a third-party app or tool to block or filter the alert. For example, you could try using a call blocker app that can silence or redirect calls and notifications.
  4. Alternatively, you could try to physically disconnect or remove any phone-related components or cables from your B&O headphones, such as the microphone, speaker, or charging cable, if possible. However, this may affect the functionality or quality of your headphones as an intercom.
Keep in mind that removing the "no dial tone" alert or disabling phone-related functionality on your B&O headphones may affect their warranty, compatibility, or safety. Therefore, it is recommended to consult the manufacturer or a qualified technician before making any modifications or repairs to your headphones.
2/25/2023 5:01:21 PM • Lands Phones • Answered on Feb 25, 2023
RCA ViSYS 5424REI Four-Line Corded Expandable Business Phone System.
Question edited for a lot more clarity. Question moved from Cellphones. Here is the manual
RCA 25424RE1 User Manual - ManualsLib
https://www.manualslib.com > manual > Rca-25424re1 It is designed to receive calls on up to four incoming telephone lines and to serve up to 16 station users. Your phone features 16 memory locations, 94 phone ... ..
2/23/2023 7:27:26 PM • Lands Phones • Answered on Feb 23, 2023
Conair clock radio phone CID502 manual please?
Question edited for clarity. Only the CID500. It might be close enough https://manualsbrain.com/en/manuals/1380396/ https://www.google.com/search?q=Conair+CID502+manual ..
2/21/2023 12:43:16 AM • Lands Phones • Answered on Feb 21, 2023
Can be this use for handpiece?
probably, except we have no idea what 'this' is and what you want to use it for. 'make model (what is it) in all questions please, with a question and some sort of explanation. "I have a Nortel 1006B Desk Phone and wonder if I can use the handpiece on my Cobra CBX-20, CB radio as a microphone"?
2/18/2023 5:13:09 PM • Lands Phones • Answered on Feb 18, 2023
2answers
How to clear all blocked calls from my KX-TG7871
To clear all blocked calls from your Panasonic KX-TG7871 phone, follow these steps:
  1. Press the "Menu" button on the handset.
  2. Use the up and down arrows to scroll to "Settings" and press "Select".
  3. Scroll to "Call Block" and press "Select".
  4. Scroll to "Block List" and press "Select".
  5. Use the up and down arrows to highlight the number you want to unblock.
  6. Press the "Erase" button, then press "Yes" to confirm.
  7. Repeat steps 5 and 6 for all numbers you want to unblock.
  8. When you are finished, press the "Off" button to exit the menu.
Note that if you want to clear all blocked calls, you will need to go through the list and erase each number individually. There is no option to clear the entire block list at once.
2/16/2023 11:06:25 PM • Lands Phones • Answered on Feb 16, 2023
Getting a busy signal when I'm trying to check the voicemails on MLS-18D.
It sounds like there may be a technical issue with your phone system after the power outage. Here are a few troubleshooting steps you can try to resolve the issue:
  1. Check the phone connections: Ensure that all the cables and wires are connected properly and securely. If you find any loose connections, plug them in firmly.
  2. Reboot the phone system: Try restarting your phone system by unplugging the power cord and waiting for 10-15 seconds before plugging it back in.
  3. Reset the phone system: Depending on your phone system, you may be able to perform a factory reset to return it to its default settings. This process will erase all the data and settings on the phone system, so make sure you have a backup of important data before doing this.
  4. Contact your service provider: If the issue persists, you may need to contact your phone service provider to troubleshoot the issue further. They may be able to identify any network or system problems that are causing the busy signal and provide additional support to help fix the issue.
I hope this helps you resolve the issue with your phone system and restore its functionality.
2/15/2023 5:51:00 AM • Lands Phones • Answered on Feb 15, 2023
Gigaset As300 Twin Dect Cordless Phone - Black Logo
4 questions posted
Top Gigaset Lands Phones Experts
Marvin
Marvin
Are you a Gigaset Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Gigaset Lands Phones
Most Popular Question
phone not working
  • Lands Phones
