20 Most Recent General Electric Profile Smartwater Ultra Plus Reverse Osmosis Membrane Questions & Answers
The tank should have only 5-10 psi when empty of water. If your unit sat for any amount of time your reverse osmosis membrane may have a problem. was all the cartridges changed? Should be yearly.
General Electric... | Answered on Jan 11, 2018
is there a precharge of air in your tank. when empty of water th?re should be about 1 bar or 14psi of air. water must be able to empty from tank. pump air in until all water is gone. if unable to empty tank has failed. also if a pumped unit, when changing filters ensure all air is bled through pump before turning it on toprevent air locking inside pump
General Electric... | Answered on Apr 28, 2017
The filters that you should replace every the six months are the two pre/post filters (FQROPF). The membrane (FQROMF) needs to be replaced every 1 to 2 years. During the filter change, bacteria could be introduced, so it is recommended that you sanitize the tank while changing the filters. Here are the filters you need to replace:
http://www.freshwatersystems.com/p-7787-ge-profile-fqropf-smartwater-ro-pre-and-post-filter-set.aspx
General Electric... | Answered on May 30, 2016
Make sure that all valves are in the open position.
Try to recharge the water storage tank. Here are the steps to follow.
* In General: When any type shut-off valve handle is positioned so that it is parallel or in line with the tubing that enters the valve, valve is OPEN. When handle is turned perpendicular to tubing that enters valve, valve is CLOSED.
Necessary Supplies:
1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.)
2) Bicycle tire pump for standard type bike tire valve
To recharge RO system tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).*
2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side.
3) Remove stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure)
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this
procedure.
6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient)
8) Turn off RO faucet.
9) Replace cap on valve stem and reposition tank in upright position.
10) Open cold water feed valve.*
11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
www.FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
General Electric... | Answered on Dec 06, 2014
If you want the reverse osmosis water to go to the ice maker then you tap in to the line that feeds the spiget on the sink.
General Electric... | Answered on Nov 24, 2014
I believe the ratio is 5-1, so when you use 1 cup it uses 5 cups to replace that cup. The reject water will slowly run down the drain, the extra four cups.
General Electric... | Answered on May 29, 2014
UV bulb install
General Electric... | Answered on Dec 29, 2013
IF THE RO OR ANY T33 FILTER HAS BEEN INSTALLED HORIZONTALLY, TRY TO INSTALL IT VERTICALLY WHERE THE OUTPUT IS ON TOP. GOD BLESS.
General Electric... | Answered on Aug 15, 2013
An RO drinking water air gap faucet would be the ideal faucet to purchase for your RO system. Here are a few options you can choose from that may come in brushed nickel: http://www.freshwatersystems.com/c-821-ro-drinking-water-air-gap-faucets.aspx
General Electric... | Answered on Jun 12, 2013
General Electric Profile Smartwater Ultra Plus Reverse Osmosis Membrane Logo
Popular Tags
53 questions posted
Top General Electric Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a General Electric Water Filter and Cooler Expert? Answer questions, earn points and help others
View Most Popular
  • General Electric Water Filters & Coolers
Most Popular Question
kinetico water filter leak
  • Water Filters & Coolers
