20 Most Recent Krups Compact Automatic Espresso XP 7245 Questions & Answers
Pull the drip tray out
Whack the silver surround on the front (see photo) upwards with the heel of your palm, it clicks up and off.
Remove beans lid, it clicks up when open
Undo 1 or 2 screws holding beans container in
Flip open or remove front top panel
Undo I think 3 screws holding top cover, 2 out wide on the top front and one down a tube in middle back.
Lift front edge of top cover up and wrack it about a but to release the clips
Undo 2 screws at the back covered by the water tank, down tubes
Remove side waste bin and sliding drawer thing
Remove 2 screws from the front through to the the sides (2x total not 2 each side)
Sides and back assembly now slide backwards, that's it, you are inside now.
Krups Compact... | Answered on Oct 03, 2015
I have a dolce gusto and i am unable to remove the coffee capsule. It seems stuck, as does the lever that punctures the capsule. If the valve lever is moved right or left nothing comes out. Please can you help?
Krups Coffee... | Answered on Dec 01, 2019
That model had a likelihood of the electrovalve growing a green crystal inside the fitting where the teflon tube comes from the boiler. The electrovalve is a solenoid operated tap on the steam wand side accessed by removing the lid and the side cover. I used to take the electrovalve off completely to do the job. To get the teflon tube out you depress the silver collar around the tube towards the fitting and pull on the tube. It won't come out unless you depress the collar. You then unscrew that same fitting and clear the green crystal out with a probe or screwdriver and rinse or blow the fitting out. The fitting was sealed from new into the electrovalve with some sort of sealant product, I used to clean out the threads and use some thread tape, I never had a leak and did heaps of them over the years.
Krups Coffee... | Answered on Nov 07, 2019
Found on the internet:
Try this, remove the tank, the drip tray, the bin on the side and the sliding thing above the bin. Hold down the on and steam buttons while plugging the machine into a live socket, it's either that or the same again but holding down the on button and the program button while plugging it in. You will get a screen that says something like " Remis a something vende" which is French for put it into sale state, you choose "Oui" for yes Hope this helps
Krups Coffee... | Answered on Oct 30, 2019
I found this on the internet:
Google (krups)(171)(manual) without parens OR contact Krups directly to request it.
Krups Coffee... | Answered on Oct 26, 2019
Hello Linda Foster,
If there is NOT an OWNERS MANUAL immediately
available.. there are a huge selection of KRUPPS
machines...
Chose from the attached list...
Find the trouble section... Read & heed
Results for krupps coffee maker var myCallback function document ready...
Hope this helps...
(or REPOST with model number for BETTER QUALITY answers).
Carnac the Magnificent
Krups Coffee... | Answered on Sep 07, 2019
Repair may consist of replacement. Leaking underneath is not a good indication.
Krups Coffee... | Answered on Aug 26, 2019
You need to ask a better question that includes the model number and exactly what program or part of the program you have issues with.
Krups Coffee... | Answered on Aug 21, 2019
what is your modle sir
Krups Coffee... | Answered on Aug 20, 2019
Google (krups)(203)(manual) without parens. You may have to refine your search to get the correct model.
Krups Coffee... | Answered on Jul 13, 2019
Krups Compact Automatic Espresso XP 7245 Logo
1 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Pierre Laplante
Charles Tidwell
Ray Murphy
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Krups Coffee Makers & Espresso...
  • Krups Coffee Makers & Espresso...
Most Popular Question
disassemble krups xp 7245
  • Coffee Makers & Espresso Machines
