20 Most Recent Sharp sh530u unlocked gsm phone Questions & Answers
i had this problem.i took the phone to service center and they upgraded the android .it became ok.i recommend u to do so first .
Sharp sh530u... | Answered on Mar 18, 2014
i have the same problem.plz inform me if u find any solution
Sharp sh530u... | Answered on Sep 05, 2013
how to check hard reset
Sharp sh530u... | Answered on Aug 03, 2013
Switch off your phone and Do a restart
- Get your data cable and connect to the PC
- Suddenly you will see the "Mass Storage Mode" Selection page.
- Then you may able to go the upper task menu and you may able to activate Wi-Fi or Data.
Thereafter you can unlock the phone using the Google credentials.
This was worked for me several times.
Sharp sh530u... | Answered on Jul 15, 2013
Do a Factory Reset on it.
Try this
Enter '3001' to cancel out the current pin which should then reset the pin to factory default of 1234.
Help with Sharp Aquos PIN code ' AVForums
https://www.avforums.com > threads > help-with-sharp-aquos-pin-code.96...
Mar 29, 2009 - Enter '3001' to cancel out the current pin which should then reset the pin to factory default of 1234. You must log in or register to reply here.
https://www.google.com/search?client=piriform&ei=fpPlXc39N869ggeWxbCICg&q=sharp+LC32LD135k+reset&oq=sharp+LC32LD135k+reset
https://www.youtube.com/watch?v=k8FIVaBjYtQ
Sharp Cell... | Answered on Dec 02, 2019
DVD drives region settings can be changed to view DVDs from different region, but on the 4th change the DVD player will lock on the 4th region change.
The DVD player can be made region free by upgrading the firmware, if it is available, but if you make a mistake the the DVD player will be a piece of junk.
The best way to make a DVD player region free is to install a piece of software on the computer to make the DVD player region free.
Please click on this link and follow my instructions to make the DVD player region free :-
http://www.fixya.com/support/r3559135-playing_dvds_from_other_regions
Sharp Cell... | Answered on Nov 07, 2019
if this is the machine your talking about check out this link to the user manual it may have the answer.
if not then you may have broken wire/s in that display. this user manual may have contact info in it so you might ask the mfg. about the issue. good luck.
https://www.manualslib.com/manual/571166/Sharp-Fv-Db1e.html
Sharp Cell... | Answered on Sep 06, 2019
You should take it to an authorized technical center. It look's like an protective mode. Maybe some electr?nico component inside it's broken...
Sharp Cell... | Answered on Jul 14, 2019
It is very easy to do. You just follow these steps and that's it.
* Go to settings
* Go to the Privacy
* Now you will see an option "Factory Data Reset" (Click on it)
* Then Click on "Erase Everything"
after that, your device will reboot itself and it will perform an operation which will reset your data from the factory.
Sharp Cell... | Answered on Apr 11, 2019
Sharp sh530u unlocked gsm phone Logo
Popular Tags
30 questions posted
Top Sharp Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Sheldon Dedek
Marvin
Marvin
Are you a Sharp Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Sharp Cell Phones
  • Sharp Cell Phones
Most Popular Question
battery replaced
  • Cell Phones
