20 Most Recent
Little Tikes My Real Digital Camera Pink Questions & Answers
Instructions for downloading images??
For
those having trouble utilizing a memory card, turn on the camera and
press right arrow key for 5 seconds until blue screen pops up. Press RC
button until screen shows a camera image on left and memory card image
on right titled "storage". Then press right arrow key to select memory
card.
Just e-mailed little tikes and they e-mailed the instructions within a couple of days. For those who lost or misplaced the instructions, you can
email them using the contact us page on their website. For faster
service, you can call their number, 1-800-748-2204, and request the
instructions. I received the instructions in two minutes.
I hope helps with this andwer, remember to rated.
"little tikes- my real camera" can't upload pics
The USB connection seams to be very sensitive try pushing the USB cable into the camera firmly and wiggling it. Once the mass storage device is recognized be careful not to move the plug. The connection can be very flaky.
Good luck,
Mike
Very poor pics on PC screen from little tikes camera
Honestly, this is a camera with very poor resolution. My I downloaded my child's photos, they looked awful. I even took my own photos and they still looked terrible.
I would try taking test photos yourself and seeing if this improves. You need to have a very steady hand and not move the camera for several seconds when taking the photos.
Little Tikes (vintage) Ride-On Train doesn't drive forward?
Question edited for clarity.
Question moved from Cars and Trucks category.
If it runs backwards, then the problem but be the forwarding part of the controller. Usually your local Model Shop will know a repairer, or they might undertake it themselves.
Trying to disassemble little tikes log cabin to no avail!!! Even searching you tube it appears such hard work and almost impossible to dismantle! Any ideas?!?
I figured out this problem today. I was ready to get a torch and saw to get it apart. It looks so simple and everything says no tools required. If your like me and bought it used, you don’t even know how it went together to reference from. So, start with the roof it’s easy to remove. For the walls I used a crowbar and brut strength. I turned it onto the back wall side. So the door should be facing up to the sky. Now, get the crowbar or something to use to get in between the roof log and the side wall log. Now pry up on the roof, push hard! The wall will slide up and break free from it’s locked together position. I quickly rejoiced and was happy when I Hurd the thunk and saw the wall moving a bit. I pulled up on the wall and quickly went back into frustration mode. But don’t fear, this is where the brut strength come in. I stepped on the wall flat on the ground and got my shoulder under the wall facing the sky. I stood up, my shoulder pushing the top wall and bam ??! One of the side wall logs jammed into the top wall came loose. After that I just kept doing the same thing and eventually was able to disassemble the rest. Two people may make this easier but I had just me and my two year old.
Tools needed: Pry bar and a strong shoulder
