20 Most Recent New Bright 384 Holiday Express Animated Electric Train Set Questions & Answers
New bright santas christmas express no, 187 train wont smoke
This goes back about 40 years for me. Both Lionel and TYCO had "smokers" in their train sets. My recollection was that the "special smoke oil" was a mixture of very highly refined kerosene and parafin wax. Try a hobby shop such as Hobby Town or some such.
11/10/2021 1:30:22 AM • New Bright 384... • Answered on Nov 10, 2021
4answers
I have two 380 Holiday
Sorry to say but New Bright does have these replacement parts hence you need to try hardware stores to see whether you can get a similar adapter . Check the V and the power it should not be an issue.
Thanks
8/31/2017 2:57:36 AM • New Bright 384... • Answered on Aug 31, 2017
HI: Ihave an old train set that needs parts
We have no parts for sale here at this website.
7/26/2017 9:00:52 PM • New Bright 384... • Answered on Jul 26, 2017
I need to replace the brushes or track contacks on
U could buy those brushes to ur nearest hobby store!
12/9/2015 9:17:25 PM • New Bright 384... • Answered on Dec 09, 2015
Rubber traction band on New Bright no.183 Locomotive, where can I get one?
Go to newbright.com . They have a technical support , or contact prompt. I'm sure they can help., or try [email protected]
1/6/2015 4:20:27 AM • New Bright 384... • Answered on Jan 06, 2015
2answers
Instructions
Not sure what instructions you need, but the setup is very simple.
1. Put your track together
2. Attach the track power connector by slipping it under the track and pushing, then lift up the other side. This will make the two metal contacts connect to the track.
3. Plug the connector from the power pack into the track module (It should only go one way)
4. Plug the control box (looks like a telephone cord) into the track module, Will only go one way
5. Place the locomotive on the track.
6. Place the Treetop Tender on the track (you need both to make it run)
7. Connect the large connector from the treetop tender to the loco
8. Turn on the command module and press forward ...
You should now be running in circles ...
Hope this helps...
11/30/2014 5:36:01 PM • New Bright 384... • Answered on Nov 30, 2014
5answers
No power to track and/or train. Power to Holiday Express Train
Check the power circuit that goes to the track if there is an open circuit, open circuit means, break or cut line that can not flow the current going to the track to give a power to the train, ok.
11/30/2014 3:07:03 PM • New Bright 384... • Answered on Nov 30, 2014
New bright greatland holiday express train
Check the connection from the transformer to the track, and that all the track is well connected. Make sure nothing is touching both tracks, shorting them out.
11/26/2013 7:26:59 AM • New Bright 384... • Answered on Nov 26, 2013
2answers
I need the controler for the SantaLand Musical Train Set
New Bright offers ONLY a 60 day replacement warranty after which there are no parts or service avaialble for this train set.
I would contact New Bright about a replacement or take it back to the store where you bought and select something other than New Bright products.
http://www.newbright.com/
11/28/2012 8:06:44 PM • New Bright 384... • Answered on Nov 28, 2012
2answers
Are transformers for the 387 and 384 interchangable?
Check the output of the transformer going INTO the controler. Mine is 19VAC. IF the controler is working you should measure 25VDC between the inner and outer track with the controller switched on. If you have the AC but not the DC voltage push the red reset button. Once you have the 25VDC put your train in place (engine and coal car) and it should run.
10/17/2012 3:02:59 PM • New Bright 384... • Answered on Oct 17, 2012
2answers
Need train transformer model #APX663004
mcdevito75 here, Contact New Bright online at www.newbright.com for the transformer. Hope this helps. I didn"t see a telephone number at the site. Sorry.
10/17/2012 2:56:39 PM • New Bright 384... • Answered on Oct 17, 2012
New Bright Holiday Express Animated Train - figures do not move
Make sure you the wheels on the cars are actually rolling and not sliding (being drug down the track) Most of the animation is down mechanically as the set moves.
12/12/2011 5:32:53 PM • New Bright 384... • Answered on Dec 12, 2011
2answers
Cars light problems
you say you have checked connections and are goodcheck the connections individually remove one car at a time check to see if it works go through the process of eliminating each rail carnarrow it down untill you find the faulty car it might be a fault in just one carhope this helps you
12/9/2011 4:57:00 AM • New Bright 384... • Answered on Dec 09, 2011
I bought a New Bright Timber Wolf & Redwood
It's supposed to be silver metal with a hole in it.
6/4/2011 8:47:44 PM • New Bright 384... • Answered on Jun 04, 2011
Hi having trouble with
Yes, additional track is available from several places, such as Hobbylinc.com, and TowerHobbies.com. At this time, just after Christmas, they are out of stock, however. Walthers.com has them in stock (1-4-2011). You can find extra track on sale on eBay, as well. Be sure to get the track with the brass covers, as New Bright sells battery powered trains that use bare plastic track, which will not work with the 384. A Google search will turn up more sources.
1/4/2011 4:11:58 PM • New Bright 384... • Answered on Jan 04, 2011
No sound
Hi, there is a HD sound box speaker fixed in the unit.if there is no sound coming that means either the speaker which is emitting the sound out is got faulty or the speaker wires have got loose or got cut in between. The unit needs to be opened and checked. It is not very hard but bit checking with meter or continuity tester is required to check the speaker and its wires....
12/25/2010 5:47:16 AM • New Bright 384... • Answered on Dec 25, 2010
I have power to the
I'm assuming the train is track powered with a power pack, and not battery powered, so there's actually a few possible solutions. I'll work from the easiest/cheapest, to the more advanced/expensive.
First, especially if the track is old or been in storage a while, the track may have a thin film of dirt, oil, or rust that is insulating the wheels from picking up the power they need from the track. Try cleaning the track with a mild soap but BE SURE TO DRY IT COMPLETELY before reattaching the power. Also, clean the wheels but use a cotton swab and very little water. One drop inside the motor might destroy it from the inside. You can also try a special track cleaning solution sold at your local hobby shop that has HO model train sets. That will work better, especially on lightly rusted parts. Also, make sure all the track connections are tight and free from contaminants.
Then, if you're feeling brave, you can check the motor of the train itself. Disassemble the locomotive and find the motor inside the housing. Check the wires leading from the wheel area to the motor for any corrosion, or loose/broken wires. If it's not the wires which are easy to solder back in place, I wouldn't recommend going any deeper into the motor as it's better and less frustrating to just buy a whole new set.
Finally, the problem may lay in the power pack (inverter) itself. I personally don't bother trying to fix a power pack, but if you know your electronics you could run some tests of the output voltage to the track, and the voltage on the track at various points. Again, it's not worth the time or effort to mess with the power pack unless you know what you're doing. You could get seriously injured or killed by the voltage/amperage running through those things. They even have enough stored electricity after they're unplugged to cause some nasty electrical burns from the capacitors.
Hope this helps and you're able to fix the problem so you can get back to enjoying the train set. I've always enjoyed watching them for hours, especially when I set up my track around the Christmas tree every year! Good luck!
12/19/2010 5:29:44 PM • New Bright 384... • Answered on Dec 19, 2010
Dear FixYa ... I have a
Is the train new and if not, has it ever gone forward in the time you've had it? Also have you tried putting the train on the tracks facing the other way - what happens?
12/5/2010 6:34:25 AM • New Bright 384... • Answered on Dec 05, 2010
Train light up...makes noises....but won't
This may indicate a short in the train's electrical system. Push the reset button on the controller. If this does not correct the problem, refer to the maintenance section of your instruction manual to clean the tracks and train car contacts. If none of these preventative measures work, you probably have either a defective controller or a short in the train's electrical system. All electrical components of the train set (transformer, track clip, controller and/or tender car) would need to be checked and faulty component has to be replaced. ------- Thanks.Helpmech.
12/4/2010 4:33:56 PM • New Bright 384... • Answered on Dec 04, 2010
New Bright 384 Holiday Express Animated Electric Train Set Logo
91 questions posted
Top New Bright Toys Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Don A
Don A
Are you a New Bright Toy Expert? Answer questions, earn points and help others
View Most Popular
New Bright Toys
  • New Bright Toys
Most Popular Question
rubber traction band new bright no 183
  • Toys
