20 Most Recent Peg Perego Ride On Santa Fe Train Questions & Answers
check it with a multimeter and make sure its showing at least 6 volts
Peg Perego Ride... | Answered on Aug 16, 2017
if you shake the battery and it sounds like there is sand in it, then the cell has dried up
Peg Perego Ride... | Answered on May 31, 2013
the red button only controls the sounds which run off of 3 aaa batteries, the black button controls the motor which runs off of the 6v sla battery, make sure that under the seat the battery is connected to the train
Peg Perego Ride... | Answered on May 14, 2012
there is no on/off switch, but you do have to take the seat off and make sure that the battery is connected
under the smoke stack
you have to take the screw out of the front of the seat and then you can plug it into the battery and then plug the other end into the wall
have to hold on the button that has arrow untill it moves
Peg Perego Ride... | Answered on Oct 08, 2010
hello there.
firstly im not very good with toy cars so excuse me if i get things slightly wrong
has the car been dissasembled at all? or had the wiring changed?
also does the vehicle have a PCB or is it all indevidually wired?
i would personally dissasemble the car and remove the control circuit board (if it has one) and inspect it for corrosion or rust, next dose the board in White vinegar and leave to rest it will remove any corrosion on the components (scrub it with an old toothbrush if possible) also if it has connectors of some sort i would spray them with WD40 contact cleaner.
lastly also spray contact cleaner into the Gear switch as that might be causing the issues...Good Luck!
Peg Perego Toys | Answered on Jul 23, 2020
Sorry we do not have parts here or any locator service to find them.
Peg Perego Toys | Answered on May 09, 2018
then contact them, you will void any and all warranty if you fiddle with it before they get a chance to fix for you .
Peg Perego Toys | Answered on Mar 04, 2018
I would suggest taking it into a service center
Toys | Answered on Aug 25, 2017
What is your question?
Peg Perego Toys | Answered on Aug 18, 2017
Peg Perego Ride On Santa Fe Train Logo
19 questions posted
Top Peg Perego Toys Experts
Marvin
Marvin
Lawrence Oravetz
john h
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
View Most Popular
Peg Perego Toys
  • Peg Perego Toys
Most Popular Question
thomas train peg perego
  • Toys
