20 Most Recent Peg Perego IGED1084 Santa Fe Train Questions & Answers
Hi, Batteries tend to fail on charging if not used for a while- try a really long charge and see - if it still fails to hold a charge - the re-chargable battery will need replacing.
Peg Perego... | Answered on Dec 07, 2017
the sounds run off of a separate battery source, check your battery connection under the seat
Peg Perego... | Answered on Aug 17, 2017
check the battery and the charger with a multimeter and make sure they are showing the correct volts, and then check the voltage wires where they connect to the motor and see if its showing the correct volts there when the foot pedal is pressed
use a multimeter and check to see if you are getting power at the motor, you should be getting at least 6 volts
Peg Perego... | Answered on Dec 07, 2012
Call peg perego directly. You want to make sure you get the correct one , you can mess up the battery with a slightly different charger.
Peg Perego... | Answered on Oct 12, 2012
are you looking for the manual for the track setup or the train setup?
Peg Perego... | Answered on May 22, 2012
I can get you one if you still need one
Peg Perego... | Answered on May 04, 2012
I can get you one, let me know if you still need one
i'd check the charger with a multimeter and make sure that its putting out at least 6 volts, prefferably 7.2volts
turn it around and have it go the other way also have your kid sit to the inside of the seat
the whistle runs by three aaa batteries, the train engine runs from the sla battery, verify that its connected correctly
you can get one on ebay for about $6 shipped, just look for a 6v1a sla charger
please verify that the battery is showing more than 6v on a multimeter, your charger might be bad
its always on you just have to push either the sound button or the gas button
the light on the charger will turn green
the horn is run by three aaa batteries, if you remove the smoke stack you can replace them there
the music is run by three aaa batteries so that will work no matter what, did you reconnect the battery to the vehicle after charging it
the wistle is run by three aaa batteries under the smoke stack on the front not the batterie that is under the seat, make sure that you have reconnected the battery properly to the vehicle
Peg Perego IGED1084 Santa Fe Train Logo
32 questions posted
Top Peg Perego Toys Experts
Marvin
Marvin
Lawrence Oravetz
john h
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
View Most Popular
Peg Perego Toys
  • Peg Perego Toys
Most Popular Question
need battery charger thomas train ride
  • Toys
