20 Most Recent Singer Nkok Sewing Machine B/O Zigzag Chainstitch Questions & Answers
You can find free manuals to down load from singer ..
http://www.singerco.com/accessories/manuals.html
Please vote !!
Singer Nkok... | Answered on Aug 26, 2020
Try going to Joann fabric. They know a ton about any machine and it's problems or try a smaller sewing store in your area. Best Wishes!
Singer Nkok... | Answered on Feb 01, 2009
Did you check the metal pin and spring terminals the batteries sit between? If a battery powered toy is stored with the batteries still in the terminals can corrode and block the electrical current from the batteries. Try cleaning the terminals with a cotton bud and Very Fine sand paper. A cardboard nail file works well for this.
Toys | Answered 3 days ago
how long are your arms??
Toys | Answered on Nov 30, 2020
Reference: Paisley Electronic Push Code Safe
Item # 5661462
Purchased at Justice. May be one of the following design/colors: 1. Pink and black 2. neon green 3. tye-dye (all in zebra pattern, I believe)
To gain access to safe without code proceed with the following simple instructions:
Use a screw driver to access batteries on the bottom of the safe. Remove all three AA batteries.
WAIT AT LEAST TEN SECONDS before reinserting betteries to functional position. Replace screw. Key in default passcode "0000#" Safe will now be unlocked and upon opening you can reset passcode. Hold down the "*" and when voice prompted to "key in passcode" enter new 4 digit code followed by the # sign... HOLD "*" until completed code with "#" You will hear the voice command, "enter passcode" after each digit entered. [Press & hold "*" (1234) press "#" release "*"] Close safe and new passcode should be set and work properly. If not, enter default "0000#" and try to reset once again.
Toys | Answered on Nov 28, 2020
Disconnect the electrical connector that joins the arches. Unscrew the half of the arch that holds the batteries. Check the red lead from the battery compartment. Mine had two problems - it was almost disconnected from the battery, and had another disconnect in the middle. Twist the wires together at both fault points and tape (electrical tape) or solder. I soldered and my Learning Home is now working perfectly.
--gdipersio
Toys | Answered on Nov 16, 2020
There are tutorials and video's on YouTube and on Goggle then on how to make your own decorations for birthdays and for Christmas and Easter and Halloween and for Valentines day too.
Toys | Answered on Nov 11, 2020
Put the crank handle in the down position and then use the arrows on the gears to guide you. The two gears that hold the two spirals should be closest to you. Make the two arrows on the gears point directly at each other(keeping the crank in the down position). The third gear's arrow (furthest from you) should point directly at you bisecting an imaginary line formed by the other two arrows pointing at each other. The idea is to get the spirals lined up so they create a channel for a ball to fit in.
Toys | Answered on Oct 04, 2020
https://directbrown.weebly.com/dreamsky-alarm-clock-radio-user-manual-ds201.html#dreamsky-alarm-clock-radio-user-manual-ds201
Toys | Answered on Sep 29, 2020
Maybe you can search on Amazon or Ebay. This manual is cetainly on sale.
Toys | Answered on Aug 28, 2020
I found this on a review of the dog:
Playing with Lucky is pretty simple but does require some learning. Lucky is programmed to respond to 15 different commands but the commands must be issued the same way each time. First, you say Lucky's name to engage him. Once you say "Lucky" (or whatever name you give him) he will then respond to you with 2 barks. After he goes ruff-ruff, then you can tell him what to do. The commands are as follows:
Speak to Me - he will sit or stand & bark
Come Here - he will run forward and back
Pounce - he will crouch and pounce excitedly
Lay down - he will lay down on his tummy
Sit - he sits
Want a Treat? - he stands and barks (begs)
On your head - He does a headstand
Go to sleep - lays down, snores and enters sleep mode
Sing a song - he'll bark one of 2 songs
Good Dog - acts excited by shuffling his feet
Bad Dog - he crouches down
Put 'em up - he'll stand up on his hind legs. Then when you say "bang bang" he plays falls down and plays dead.
Tug of War - he opens his mouth for you to put in his leash, he closes his mouth and tugs a little
Lucky also comes with a "sleep" mode and automatically shuts off after not being played with for 3 minutes.
Playing with Lucky is pretty simple, you command and Lucky performs. Well, Lucky performs most of the time. You need to be sure that he has your attention (barking twice) first before issuing the command. A few of the tricks are a bit more complicated - Put 'em up & Tug of War but the rest are very straight forward. I do notice that both my husband and I had the tendency to want to 'yell' or raise our voices when commanding Lucky - but that isn't necessary.
Toys | Answered on Aug 15, 2020
Helps to get back each and every inaccessible Outlook items such as emails, calendars, notes, tasks, journals, contacts, etc from Outlook personal folders and make them workable without loss any data. See at:- Outlook Emails Recovery
Toys | Answered on Jul 27, 2020
Singer Nkok Sewing Machine  B/O Zigzag Chainstitch Logo
14 questions posted
Top Singer Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Singer Toy Expert? Answer questions, earn points and help others
View Most Popular
Singer Toys
  • Singer Toys
Most Popular Question
looking instruction manual
  • Toys
