20 Most Recent
Casio TC-930 900MHz Cordless Phone Questions & Answers
TC-925 info
Are you looking for the TC 925 or the TC 930?
Casio have a list of manuals on their website
http://www.casio.com/support/manuals
http://www.casio.com/support/manuals/telephones/tc919.pdf
Theres a TC919 shown there, take a look at this it may be the same setup for your unit
This may be of help.
Pick up rings
Here is the manual for the TC-919 which is very similar
right in the top left of page 1 is a descrition of the ring select switch on the back of the base unit - this model can be changed only between 2 and 4 rings, but perhaps there is an option for 6 on your model
The way to get a manual for your exact model if this one doesnt answer your questions is to call 609-395-0154 and request one.
Hope this helps - please ask again if you have no success :)
The one hole outgoing message tape will it work on a 4200 and a 4300 Casio phonemate answer machine?
To determine if the one-hole outgoing message tape will work on your Casio Phonemate models 4200 and 4300, I recommend the following steps:
- Check User Manual: Consult the user manual or documentation for your Casio Phonemate models. Look for information about compatible tape formats, sizes, and specifications. The manual may provide guidance on the type of tape that can be used for outgoing messages.
- Contact Customer Support: Reach out to Casio customer support or the manufacturer's official website for information about tape compatibility for the models 4200 and 4300. They should be able to provide specific details about compatible tape types.
- Trial and Testing: If you have access to the one-hole outgoing message tape, you could try testing it on the models 4200 and 4300 to see if it functions correctly. Make sure to follow any installation instructions provided in the user manual.
- Seek Expert Advice: If you're unsure about compatibility or encounter any issues, consider seeking advice from experts who specialize in telecommunication equipment or the specific Casio Phonemate models.
How do you remotely access casio phonemate TA-116
Look on the underside of the unit. You will see a three (3) digit number. When you remotely call your number and the answering maching picks up, immediately input the 3 digit number. The answering maching will then play the new messages for you.
When I make calls on my Casio Commando no one can
GO INTO MENU AND SET YOU PHONE ON HOW YOU WANT TO MAKE AND RECEIVE YOUR CALLS.
YOU MAY HAVE YOUR PHONE SET ON HEARING IMPAIRED OR YOUR BLUETOOTH MAY BE ACTIVATED AND THIS WILL MAKE YOUR CALLS BE HEARD ON SPEAKER. YOU WILL NEED TO UNCHECK THESE SETTINGS.
YOU CAN ALSO GO INTO MENU AND JUST RESET SETTINGS!
HOPE THIS HELPS!
