20 Most Recent Life Fitness 9100 Elliptical Cross Trainer Questions & Answers
The battery is definitely the #1 culprit in this situation. When you use the machine, you actually help keep the battery charged. When the machine is not in use, it gradually loses its ability to hold a charge.
Video about How to Test Battery
Life Fitness... | Answered on Aug 26, 2014
Chances are, if it has not been used in over a year, the battery would need to be replaced. You may be able to recharge, but more than likely the battery will not hold the charge long, if at all.
Repair Parts for LifeFitness CT9100 Crosstrainer Ellipticals SPORTSMITH...
Life Fitness... | Answered on Aug 03, 2014
Check the battery voltage.
Life Fitness... | Answered on May 20, 2014
Start with checking the voltage output from the battery.
You can use the link below to purchase a suggested form of lubrication. You may end up needing to replace a bearing or bushing.
Silicone Spray Lube by SPORTSMITH 9 Oz SPORTSMITH net
The treadmill has a 'folding' feature for the incline setting. A safety switch must be reading this feature as not locked. Try this. Set the incline to 0% and the speed to zero. Step in front of the treadmill and using both hands carefully raise the whole front until the legs click and lock into place.
To lower the treadmill kneel behind the treadmill. Place your Right hand on the belt and lean your weight on it. At the back of the treadmill on the Left side panel is a lever. Pull this lever until the treadmill stops lowering.
Life Fitness... | Answered on Sep 10, 2020
Likely the excitation to the alternator in this recumbent bike has dropped out, but there may be other causes.
You might start with this reference, which is how to access the various components:
Life Fitness... | Answered on Apr 10, 2019
very possible. after i moved many miles away i had to disconnect and reconnect theconnectors on my Lifestepper
Life Fitness... | Answered on Mar 05, 2019
Life Fitness 9100 Elliptical Cross Trainer Logo
8 questions posted
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Thomas Perkins
Thomas Perkins
gbob59
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Life Fitness Exercise & Fitness
Most Popular Question
display not working used over year
  • Exercise & Fitness
