20 Most Recent Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth Pandora Link,iPod Support & Questions & Answers
My Pioneer DEH-X6500BT skips when the volume is turned up.
Question edited for clarity. Question moved from Computers This appears to be a known issue. https://www.google.com/search?q=Pioneer+DEH-X6500BT+sound+skipping ..
3/4/2022 1:51:28 AM • Pioneer... • Answered on Mar 04, 2022
2answers
How do I reset my pioneer deh-x6500bt car stereo and produce sound from my rear speakers?
a 'reset' of the entire stereo should be able to be accomplished by disconnecting the battery for several minutes: alternately if you remove the faceplate there should be a reset button you would need a pen to press, however you should be able to find the EQ levels and set the balance and fade I think it is so the rear produces sound, if that is not the case, I would check wiring to make sure nothing is loose. I suppose it could only be a software/firmware problem with the stereo itself however, if you have had this happen before and it was fixed without tinkering with the wiring.
11/15/2017 12:44:05 AM • Pioneer... • Answered on Nov 15, 2017
Pioneer DEH-X6500BT amp & speaker problems
Depending on the car and your setup sounds like the amplifier is not wired properly or an issue with adjustments on your deck itself. More info on your sound setup would be helpful.
11/6/2014 3:21:48 PM • Pioneer... • Answered on Nov 06, 2014
Why pioneer deh-x6500bt wont turn on now?
Axle and Music system are interdependent of each other. Check fuses and wiring of music system.
6/18/2014 1:49:14 AM • Pioneer... • Answered on Jun 18, 2014
0answers
Amp error
take it to a certified mechanic to check out the amp. its likely the amplifier burnt out or disconnected.
11/15/2013 4:39:14 AM • Pioneer... • Answered on Nov 15, 2013
How do i turn off demo mode deh-x6500bt
that sounds like it was wired incorrectly, if your accessory power is 'off' (key off) the head unit should not be receiving power, and should not stay on, you might have power coming directly from the battery instead of accessory power.
9/29/2013 2:10:45 PM • Pioneer... • Answered on Sep 29, 2013
0answers
0answers
Deh-x6500bt cuts out at high volumn
I have the same problem, it's only when the bass comes in, and it starts to cut at half volume.
My wiring is correct and every possible problem to do with the car and its wiring have been eliminated.
-Apart from plugging the unit into another vehicles loom.
8/11/2013 11:23:10 PM • Pioneer... • Answered on Aug 11, 2013
I'm attempting to install a pioneer stereo into my son's 74 Chevy pickup.
it plugs in to the the plugs you unpluged from the original radio if there are no plugs then your going to have to wire it all up from scratch new power wires new speaker wires and just alot of work so I hope you didn't cut the plug off the old radio
3/24/2013 5:39:28 AM • Pioneer... • Answered on Mar 24, 2013
I just installed my Pioneer DEH-X6500BT for my 2004 Subaru Outback. However, the radio reception is very poor. The radio sounds very staticky
I suspect that the antenna connection is not completely connected. If an adapter was necessary, check that as well. Good luck!
1/20/2013 9:16:01 PM • Pioneer... • Answered on Jan 20, 2013
Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth Pandora Link,iPod Support & Logo
Popular Tags
21 questions posted
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Car Audio & Video
Most Popular Question
pioneer deh x6500bt skips when volume
  • Car Audio & Video
