20 Most Recent Peavey XR1212 12-Channel Mixer Amplifier - Questions & Answers
Hi Sean! Same problem. Initially the LEDs flashed on and off. In the end the LEDs finally stopped flashing and and just blinked once when I turned it on.I took it to a Peavey repairer and found that a couple of transistors were blown He ended up replacing the board. He seemed to think that dodgy speaker leads may have caused the problem. Maybe the flashing is just a warning. Don't ignore it! Hope this helps.
Peavey XR1212... | Answered on Nov 30, 2012
No It wont, is this a new amp you installing or is it already been installed and was working?
Peavey Car Audio... | Answered on Feb 18, 2014
Try this. Turn the ignition on, with the engine off. Turn on the radio. Press and hold button 4. The display should change. Use the Tuning buttons to enter the code. (I think its up/down to change the numbers). Enter the first number and press button 5 to confirm. Use the tuning buttons to move along to the next number, (i think it's left/right for this bit). Repeat the method for the first number, (Set number then press five to confirm). Once you enter the last digit the display should switch back to the normal display and be ready to use.
Car Audio &... | Answered on Oct 19, 2020
It would be best if you pull the fuse panel off while your car is switched on. Pull the fuse out for about a minute! Then put the fuse back and push the power button. I hope it will solve your problem.
Car Audio &... | Answered on Oct 15, 2020
How to change japanese to english language radio VXH-089CV
Car Audio &... | Answered on Oct 14, 2020
here you go .
http://www.gps-guru.com
Car Audio &... | Answered on Sep 28, 2020
check there...
Car Audio &... | Answered on Sep 23, 2020
Make sure take voltmeter and test wires before you make any connections. In some modern (boats, cars etc) applications YELLOW is NEGATIVE (used to be memory).
Car Audio &... | Answered on Sep 16, 2020
Do you know the make and model of the radio?
You state that you are trying to unlock the radio, but at what stage are you:
1) Do you have the security code and you are just trying to enter it?
2) You do not have the security code and you are trying to get the radio serial number?
3) Something else?
Car Audio &... | Answered on Sep 07, 2020
i chane NDDA w56 language
to english
Car Audio &... | Answered on Sep 04, 2020
need keycode of rds 4000 serial m072730
Car Audio &... | Answered on Aug 16, 2020
It's easy, please read an follow these steps: https://rent.toyota.co.jp/eng/service/navi.html
Car Audio &... | Answered on Aug 14, 2020
Attach a picture and give more information on the model and installation.
Car Audio &... | Answered on Aug 02, 2020
Peavey XR1212 12-Channel Mixer Amplifier - Logo
Popular Tags
1 questions posted
Top Peavey Car Audio & Video Experts
Marvin
Marvin
Tom Chichester
FastHarley
FastHarley
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Peavey Car Audio & Video
Most Popular Question
powered peavey xr1212 board keeps
  • Car Audio & Video
