20 Most Recent
Eiki LC-X1100 Multimedia Projector Questions & Answers
Can get any power on on my eiki lcx 1100 projector
Thermal fuse, located under the lamp might be activated, open lampdoor and push carefully the little black pin. If it gives a click it was
activated due overheating. If not, replace 1uF, 2.2. uF and 220 uF capacitors in primary part of the power supply, it takes some work to get the pcb out of this model !!
Eiki LC X1100 - the unit is loosing all power [no
in primary power-supply circuit there are 2 smd capicitors,1uF and 2.2uF, replace them both by standard radial 105 C electrolytic, also replace the 220uF capacitor that is located beside these 2.
My Eiki lc-x1100 is not
i would check the physicality of the lamp. once you've removed it, look around the filament of the lamp, and if you notice any dark corrosion build around it, then that's what's causing the dim image. if it looks clean and clear, it might be one of the mirrors within the projector's optical engine.
