20 Most Recent NEC Dterm DTP 32D-1 Corded Phone Questions & Answers
Dtp 32d manual
The DTP phones work on at least 8 NEC systems, so please mention which one you have. Pro II, IPK, IPK II, Elite, SV8100, SV8300, SV8500, 2000, 2400, or one of the more run of the mill systems. Some vendors have PDF versions on their website if you Google the specific guide you need, and add PDF in your search.
7/24/2014 9:23:34 PM • NEC Dterm DTP... • Answered on Jul 24, 2014
I think the ringer is off on my NEC Dterm 80
Ringing is assigned in system programming, so if your phone doesn't ring you can't change that unless you have person on site who works on the system at that level. Some places use the night mode feature to make certain phones ring in day mode, and others to ring in night mode. Not very likely but sometimes the mode gets switched at places who don't realize they have another mode, suddenly only 2 phones ring instead of ...5. Feature,80,Feature, is the code to switch back and forth on a Pro II, an Elite, and an IPK system. This would be done at the reception phone. These phones also work on several other systems so don't know if this works for you. Or maybe you set Do Not Disturb, which would keep your ringer off.
7/12/2014 4:36:07 AM • NEC Dterm DTP... • Answered on Jul 12, 2014
0answers
3answers
I'm trying to update the
Hi there Anna,
Try these steps:
1. Speak ON
2. Key in 7 1 8
3. Choose 2 for Night
Please let me know if this works or if you need further instructions.
4/21/2010 4:27:26 AM • NEC Dterm DTP... • Answered on Apr 21, 2010
Voice mail not answering
Press speaker, 43, xxx, speaker. "xxx" is the number of your company's message box, if you know that.
10/20/2009 10:21:54 PM • NEC Dterm DTP... • Answered on Oct 20, 2009
Do not disturb
If DND is Programmed on your phone
4/19/2009 4:50:57 AM • NEC Dterm DTP... • Answered on Apr 19, 2009
Need help fixing the date on the phone
The Time and Date come from the PBX,,
4/19/2009 2:15:22 AM • NEC Dterm DTP... • Answered on Apr 19, 2009
NEC DTERM SERIESI
You may be right about it coming from another extension! If that is the case you need to return the message by pressing the key, finding out what extension is ringing and answer the phone otherwise the message will never be returned and the message light will stay on.
Quite an annoying feature with many phone systems. Nobody ever uses the feature and people have no idea what's happening when someone else accidentally presses the wrong key at the wrong time.
10/31/2008 1:28:14 PM • NEC Dterm DTP... • Answered on Oct 31, 2008
Transferred calls
sounds like the phone transfer numbering is out of sync or someone thinks its funny to send there transfered calls
i would go with the lessor of 2
phone numbering extensions example=
say you want to call someone at 2430 ext. but it takes you to 2340 that would be phone interupt extention box
the phone company who installed the software should come out and make sure the extensions are to the correct offices its there service but you pay for quality service to know and see it works
to send back calls just transfer back to secretary switch board the secretary will know what to do
5/7/2008 11:11:41 PM • NEC Dterm DTP... • Answered on May 07, 2008
Need help with re-setting time, date etc - haven't got a user guide or manual
If your telephone system is an NEC IPK, Pro II, or Elite, you should be able to go to extension 100 or 101 and dial Feature 9 and enter the new time. To switch between am and pm, press the Recall key after you enter the new time. If your extension numbers do not include 100 or 101, this should work from the 2 lowest extension numbers. The type telephone you have can be used on other NEC systems, and these instructions will only work on the ones I listed above.
3/16/2007 12:51:07 AM • NEC Dterm DTP... • Answered on Mar 16, 2007
I have a red flashing light on a NEC DT400, it is the reception ext key. How do I cancel it out?
To cancel the red flashing light on the NEC DT400 associated with the reception extension key, follow these steps: Hold the Exit Key: Press and hold the Exit key. Select MW (Message Waiting): While holding the Exit key, select the MW (Message Waiting) option. Choose "All": From the available options, choose "All". This should help resolve the issue related to the reception extension key. If you encounter any further difficulties, consider referring to the NEC DT400 User Manual or contacting your NEC Authorized Supplier for additional assistance.
4/22/2024 6:10:06 PM • NEC Lands Phones • Answered 2 days ago
How can i fix message 14 on nec sl1000
To address Message 14 on the NEC SL1000, follow these steps: Hold the Exit Key: Press and hold the Exit key. Select MW (Message Waiting): While holding the Exit key, select the MW (Message Waiting) option. Choose "All": From the available options, choose "All". This should help resolve the issue related to Message 14. If you encounter any further difficulties, consider referring to the NEC SL1000 User Manual or contacting your NEC Authorized Supplier for additional assistance.
4/22/2024 6:06:23 PM • NEC Lands Phones • Answered 2 days ago
I need a manual for NEC BDS 22-BTN 80573 66240705 it's an older telephone.
If it is available, it will be here, or ask NEC Support direct. https://www.google.com/search?q=nec+bds+22-btn+manual The Google search query for this is simply NEC (model) manual but you seem to be putting '22 BUTTONS' mixed in with the model number. The most effective search queries are the shortest ones. https://www.google.com/search?q=nec+bds+80573+manual ..
4/3/2024 4:22:44 PM • NEC Lands Phones • Answered on Apr 03, 2024
NEC Dterm DTP 32D-1 Corded Phone Logo
34 questions posted
Top NEC Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
NEC Lands Phones
  • NEC Lands Phones
Most Popular Question
voice mail not answering
  • Lands Phones
