20 Most Recent
2005 Kymco People S 200 Questions & Answers
I bought a 2005 kymco
YES, THIS MODLE HAS A OIL INJECTION AND ANY TWO STROKE OIL WILL WORK BUT TRY AND STAY WITH A MOTOR CYCLE TWO STROKE OIL THERE IS A DIFFERANCE
KYMCO Sputters and Dies at random
Filling the tank full is okay. The problem sounds like condensation in the gas tank has made it to the carburetor. There should be a screw or drain plug on the side or bottom of the carb float bowl. Drain the carb and also drain some gas from the fuel line to remove any water and trash in the system. Chances are this will get you back on the road.
How do you remove the rear wheel on a Kymco People
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE
REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Does the Kymco People S 200 have an alternator?
To keep things clear for you i've listed 2 things for you to check.
1.
Your bike produces its own power. It consists of a stationary stator with a (pick-up/pulse) signal generator
The rotor/flywheel is mounted onto the keyed crankshaft, and secured with a nut.
This will be on the right side of the motor, you'll have to remove a cover to get to it.
I would have this tested with an ohm meter before you remove anything.
Pulse generator coil resistance should read 70-130 Ohms.
2.
Your battery produces power to start your enegine and run some lights. After some time your battery would go dead if not recharged. Your bike has a Voltage Regulator & Rectifier built into one unit, which some people call just a voltage regulator, and some people call it an alternator.
Your above mentioned stator produces an electrical current called AC power, which probably only runs the headlights, and the rest of that AC power is converted to DC power via the Alternator/Voltage Regulator, which runs the rest of the lights and horn, etc.
Your alternator should put out 13.5 - 15.5 Volts @ 5000 rpm.
Any other reading means your Alternator is bad. Too low undercharging Too high overcharging.
Test your alternator at the battery when the motor is running.
If you need to replace your alternator, it is located under the (nose)front plastics.
Usually a 4 prong plug and one bolt securing it to the frame.
HI, I was asked by
Yes you can charge the battery with a battery tender, or battery charger, when the bike is sitting.
Your People S 200 requires a 12 v, 6Ah battery.
Fully charged will have 13.1 Volts
Undercharged 12.3 Volts
Most battery tenders use low amps to charge and wont overcharge your battery.It just maintains it at 12.5 Volts.
If you use a battery charger, be sure you monitor it regulary, as some models don't shut off.
After re-building my 150 (08) scootcoupe engine
Hi! I strongly suggest that you put in a genuine kymco crank assembly. Since you made some modifications, a kymco crank may resolve this. Since it's a trial and error thing for a modified scooter, the genuine crank will be close enough on resolving this. Hope this helps and thank you for using FixYa!
