20 Most Recent Schumacher 1000 Watt Inverter with 2 GA. 100-Amp "O" Ring Cables with Screw-Down Termi Questions & Answers
Yes, just be sure connections are heavy enough wire, and obviously the inverter uses 12 vdc input. Hook jumper wires positive to positive, negative to negative, on all 12 volt batteries. Deep cycle batteries will work better than car batteries. Just remember, when re-charging them, that they last longer when charged slowly, so don't use a high amp setting on charger and to monitor them closely, and do it in a well ventilated area, away from any ignition sources.
Schumacher 1000... | Answered on Apr 15, 2010
you can search in the local repair section of fixya for a repair shop,for you problem,are you sure your batteries are still in good working condition i.e reading 12volts when battery is low
Schumacher 1000... | Answered on Feb 25, 2010
most inverter devices will charge in the off position
Schumacher... | Answered on Oct 05, 2018
With inverters and generators, the power rating is usually off by about a quarter.
Watts and volt-amperes are totally different and sometimes inverter manufacturers don't tell about the difference. A basic rule of thumb is to take whatever the inverter is rated for and knock a quarter off. So, in your case it would be best to assume a maximum rating of 1500 watts.
Also, inductive loads like drillers (electric motors) usually have a start-up current 3 to 8 times the rated operating current. Meaning that 100 watt driller will draw 300 watts to start up. So, if you use an electric motor rated at 700 watts, its startup load would be 2100 watts or even more and thus trigger the inverter overload switch. Hope this helps you.
Schumacher... | Answered on Dec 20, 2017
i normally mount it under my seat run one lead straight to the positive (red) lead of battery with a 30 amp fuse using an inline fuse holder fully sealed.than the ground (black) using a ring connector to the chassis or seat mounting stud.must run positive under carpet and through fire wall using a grommet or other possible wire channels.
Schumacher... | Answered on Aug 17, 2014
There are several ways to do this and several complications that may arise. That said, here is a brief outline of one method:
1. Locate the music folder on your PC.
2. Insert your flash drive into the USB port (allowing time for it to install or access drivers).
3. Click on Start, select My Computer. Locate your flash drive (most likely list as Removable Disk or the brand name of the flash drive). Double click on that icon.
4. Right click the folder or music files you found in step 1. Select "Send to" and choose "Removable Disk." The transfer process may take several minutes depending upon the number of files you are transferring. After the transfer is complete, click on the USB flash drive icon on the Windows task bar and select Stop or Eject. The PC will advise you when it is safe to remove the flash drive.
Here is a link to other ways to put music on a Flash Drive:
https://www.wikihow.com/Put-Music-on-a-Flash-Drive
https://www.youtube.com/watch?v=EQ4HSnlJiao
Electronics -... | Answered on Aug 03, 2020
  1. Remove the memory card from your camera.
  2. Insert the memory card into your laptop's PC card slot. ...
  3. Locate the destination folder where you want to store your pictures, in your laptop. ...
  4. Open the destination folder of your choice [source: Dummies.com]. ...
  5. Select Import pictures to my computer from the choices offered.
Electronics -... | Answered on Jun 17, 2020
I had the same problems but solved it by uninstalling the useless POS software, rebooting the computer and reinstalling everything.
I have found that you have to do this everytime that you want to add or delete photos. Probably the worst piece of software I have seen in 15 years of working on computers.
If it won't detect as a seperate drive in "My Computer" then you will have to uninstall it and start again.
There is also no need to format the device. Just ignore it and start downloading photos and it worked straight away. (Using XP Home) As to battery life, I suspect I will never know because it is liable to have a visit from my sledge hammer before it runs out of power.
Electronics -... | Answered on Jun 08, 2020
https://www.yaskawa.com/about-us/contact-us?_yascontactus_WAR_yascontactusportlet_selectedDocumentId=DRV-5P2JGY&_yascontactus_WAR_yascontactusportlet_safetyText=true
Most memory cards have a small recessed tab that you can slide to lock the card. There is usually a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
Try looking to see if your card has this feature and if it does slide it to the up or opposite position from where it is.
Electronics -... | Answered on Apr 22, 2020
Schumacher 1000 Watt Inverter with 2 GA. 100-Amp "O" Ring Cables with Screw-Down Termi Logo
Popular Tags
3 questions posted
Top Schumacher Electronics - Others Experts
ray012965
Tim Brauer
Tim Brauer
Are you a Schumacher Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Schumacher Electronics - Others
Most Popular Question
1000 watt inverter along regular
  • Electronics - Others
