20 Most Recent
Schumacher 750 Watt Power Inverter w/Digital Display By Questions & Answers
Have a 2000w inverter in
With inverters and generators, the power rating is usually off by about a quarter.
Watts and volt-amperes are totally different and sometimes inverter manufacturers don't tell about the difference. A basic rule of thumb is to take whatever the inverter is rated for and knock a quarter off. So, in your case it would be best to assume a maximum rating of 1500 watts.
Also, inductive loads like drillers (electric motors) usually have a start-up current 3 to 8 times the rated operating current. Meaning that 100 watt driller will draw 300 watts to start up. So, if you use an electric motor rated at 700 watts, its startup load would be 2100 watts or even more and thus trigger the inverter overload switch. Hope this helps you.
How should I hook up a 2000 watt schumacher inverter to a 12volt battery
i normally mount it under my seat run one lead straight to the positive (red) lead of battery with a 30 amp fuse using an inline fuse holder fully sealed.than the ground (black) using a ring connector to the chassis or seat mounting stud.must run positive under carpet and through fire wall using a grommet or other possible wire channels.
Problem with oelmaier pac2 inverter
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjckMaPzKODAxUVj4kEHR5mBFMQFnoECBQQAQ&url=https%3A%2F%2Fforums.whirlpool.net.au%2Farchive%2F1447917&usg=AOvVaw1FGjdFQoufkwdXZJgXWdGz&opi=89978449
