20 Most Recent
Boxlight CD 850m Multimedia Projector Questions & Answers
Boxlight cd-850m won't turn on
You must reset the lamp timer after you replace the lamp before the unit will turn on. Do this:
Power on the unit. On the projector's keypad, hold down the the two volume keys simultaneously for 10 seconds. At that point the LED will turn green. Now you can turn on the unit again and it should work.
Boxlight CP-670K no video
in the menu option,under signal source , select option manual(deactivate auto search) & then connect inputs & try selecting each source from the remote
If this does not work then the main board is at fault
RE: Vibe USB Turntable Model:
your choice of "Vibe" turntable could have not been worse.
Any serious Vinyl collector would not use such a cheap piece of equipment.
You Get What You Pay For is so very true in this case.
