20 Most Recent Intermatic Outdoor Timer/Photo Control HB51RC Questions & Answers
Hb51r manual
Plug in make sure bulbs work rotate dial to set choice of delay times timer turns on at dusk,,, and delays off for amount of time you choose http://waterheatertimer.org/Intermatic-timers-and-manuals.html#outdoor Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/13/2014 1:31:39 AM • Intermatic... • Answered on Aug 13, 2014
0answers
How to program a intermatic outdoor timer/photo
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
1. Turn dial selector to the "off" position and
plug timer into three conductor outdoor outlet.
2. Turn dial selector to timing interval
desired (i.e., 2 Hrs, 4 Hrs, 6 Hrs, 8 Hrs,
dusk to dawn, etc.).
3. Plug outdoor lights into Easy-Set™ Timer -
lights will turn on automatically at dusk.
4. Lights turn off 2 4 6 or 8 hours later
depending on dial selection
7/30/2013 6:20:36 PM • Intermatic... • Answered on Jul 30, 2013
Instructions. for HB51R timer
Check out the HB61RC manual from Intermatic, here. I can't find an HB51R manual, but hese devices look very similar and probably operate the same way. I'll see if I find anything more - and will post it if I do. If this works - let me know - thanks & good luck!
11/28/2011 11:21:32 PM • Intermatic... • Answered on Nov 28, 2011
Can I use outdoor timer
If outdoor timer is programmable, and does not turn ON automatically at dusk, then timer can be used indoors.
If outdoor timer is activated by photo eye, and turns ON automatically at dusk, then it cannot be used indoors, because the timer turns ON when it senses darkness.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#HB51
7/30/2011 3:06:29 AM • Intermatic... • Answered on Jul 30, 2011
Reference HB51R. When it
it may be the wiring down stream,isolate the timer to a single device just after the timer
6/12/2011 2:42:11 PM • Intermatic... • Answered on Jun 12, 2011
HB51R is "on" all the
HB51 appears to be an automatic timer
Capacity is 1000Watts
Your lights are on so the circuit has power
I don't see any troubleshooting steps
It gives you a choice how many hours your lights stay on after dusk
You might try changing the selector to a different stay-on hour.
Turn timer off and unplug and then re-plug timer to see if it re-sets.
Otherwise, it looks like the photocell or 'timer brain' stopped functioning.
5/22/2011 5:33:23 AM • Intermatic... • Answered on May 22, 2011
How do I get it
You posted under Intermatic make HB51 timer.
If this is not your timer, then add a comment.
To set for ON at dusk, and off 4 hours later, rotate dial to the number 4.
Timer turns on automatically at dusk because timer has photo eye.
Timer set to 4 hours will start countdown when timer turns ON > and 4 hours later timer will turn off.
Make sure timer is turned away from lights so photo-eye doesn't receive feedback.
Feedback is when the photo eye gets too much light, and then timer thinks it's dawn, so lights turn off, and a moment later photo eye thinks it's dusk again and lights turn on.
Feedback from lights will cause timer to reset the 4 hour countdown.
A car pulling in driveway can cause feedback.
If timer resets because of feedback, it begins 4 hour countdown again, so lights will not turn off until much later than planned, or not turn off until dusk.
You can test timer by putting black tape over photo eye, and then timer will turn on.
Set timer for 2 hours for example and then check if timer turned off 2 hours later.
If timer is not functioning correctly, then timer is defective.
12/19/2010 4:43:37 AM • Intermatic... • Answered on Dec 19, 2010
My intermatic time HB51R flashes on and off when
I think the timer's photoelectric eye is getting too much light from the Load it turns on.
To check this, set timer at 2 hours, and then put black tape over the photoelectric eye so timer senses that it is dark and turns ON.
If timer does not blink with black tape, then problem is too much light with will cause on-off cycling of the timer.
If timer blinks with black tape over the eye, then timer is suspect. Exchange timer for another one.
12/16/2010 6:59:05 AM • Intermatic... • Answered on Dec 16, 2010
Lights continue to go off
Maybe the lights are causing photoelectric eye to sense that it's no longer dark.
This is called feedback.
To check this, set timer for 2 hours.
Put black tape over photoeye.
Check if timer turns on-and-off.
If timer continues to blink, then timer is suspect. Return it for another one.
If feedback is causing the problem, then turn timer away from lights or place obstruction between timer and lights.
12/16/2010 6:58:11 AM • Intermatic... • Answered on Dec 16, 2010
Setting
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk + override lets timer run during daylight hours
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Push selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
12/14/2010 11:26:53 AM • Intermatic... • Answered on Dec 14, 2010
How do I set the hb51r so it turns on and off
manual for HB51RC
See timer at Amazon
Timer turns on automatically at dusk unless you set override feature shown below
F > Lights are OFF
O > Constant ON
From these instructions, you should push button until 6 displays. Timer will turn ON at dusk and turn OFF 6 hours later
If timer.
If you want timer to turn ON immediately and turn OFF 6 hours later, push button until 6. shows in display.
If timer does not display or does not operate correctly, then timer is suspect. Return timer for another one.
12/14/2010 11:25:47 AM • Intermatic... • Answered on Dec 14, 2010
Will the HB51R have to
The dawn to dusk feature is activated by photoelectric eye that senses when it gets dark.
If you put timer in a dark room, it will turn ON ... let's say to operate Christmas tree after you leave a room for the evening.
But if room stays dark, the timer will not sense when to turn off unless you also set timer to turn off 1-9 hours after ON.
That being said, a Christmas tree might make too much light for the timer's photoelectric eye.
Make sure photoelectric eye is turned away from direct light.
12/14/2010 11:16:15 AM • Intermatic... • Answered on Dec 14, 2010
How do I set timer
manual for HB51RC
See timer at Amazon
Rotate selector button and choose one of following
F > Lights are OFF
O > Constant ON
12/14/2010 11:07:57 AM • Intermatic... • Answered on Dec 14, 2010
How do I set it
I see nothing in the manual that says 'outdoor use only' EXCEPT timer runs on photoelectric eye.
Timer turns ON automatically at dusk, so if timer is inside, and indoor lights are ON, then timer stays OFF.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb51rc%20-%20english.ashx
To use timer outdoors.
Plug timer into wall.
Timer turns ON automaically at Dusk.
Rotate dial to set how long timer will stay ON.
Set timer to turn OFF 2 4 6 8 Hours after dusk
Set timer to turn off at dawn
Set timer to ON so lights are ON full time
Set timer to OFF so lights are off full time.
12/10/2010 4:51:55 AM • Intermatic... • Answered on Dec 10, 2010
I have an intermatic HB51R.
I don't think it is supposed to be in the "on" position when setting it up.
Turn dial to "off".
Then plug timer into grounded outlet.
Turn dial to 2, 4, 6 or 8 hours to run after dusk.
Plug in your outdoor lights.
Wait until dusk.
Let us know if this works.
12/9/2010 1:14:10 AM • Intermatic... • Answered on Dec 09, 2010
2answers
Replaced Intermatic E-1020 and the fan won't shut off. The fan is controlled by a simple on/off switch with the Intermatic wired into that circuit.
If the fan won't shut off after replacing the Intermatic E-1020, there may be a few potential causes to consider. Here are a few steps you can take to troubleshoot the issue: Check the wiring: Double-check that the wiring is correct and that all connections are secure. Make sure that the Intermatic E-1020 is wired into the circuit correctly and that the fan is wired into the Intermatic correctly. Refer to the wiring diagram in the installation instructions to ensure everything is in the right place. Verify the settings: The Intermatic E-1020 has multiple settings, including time settings and override settings. Make sure that the timer is set correctly and that any overrides are disabled. Check the manual for the specific settings and instructions on how to adjust them. Test the switch: Verify that the on/off switch for the fan is working properly. Turn off the power to the circuit and disconnect the switch. Test the switch with a multimeter to ensure that it is functioning correctly. Check the fan: Verify that the fan is working properly. It's possible that the fan itself is faulty and is causing the issue. Turn off the power to the circuit and remove the cover for the fan. Test the fan motor with a multimeter to ensure that it is functioning correctly. If none of these steps resolve the issue, it may be necessary to consult with an electrician or HVAC technician for further assistance.
3/19/2023 3:40:53 PM • Intermatic... • Answered on Mar 19, 2023
Intermatic Outdoor Timer/Photo Control HB51RC Logo
25 questions posted
Top Intermatic Hardware & Accessories Experts
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Intermatic Hardware & Accessories
Most Popular Question
hb51r manual
  • Hardware & Accessories
