20 Most Recent Paragon 1015-00RS Indoor Multi Operation Timer Questions & Answers
You won't be able to find parts for that timer unless e-bay is selling used timer.
Patriot supply sells new timer, Aug 2011:
http://www.patriot-supply.com/products/manufacturer_detail.cfm?manu_id=191
Paragon is no longer making timers and parts except defrost timers.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
Intermatic crossover timer is 120Volt T1975, which sells for less and has replaceable 156T1978A trippers and WG733 clock motor. Relay is not replaceable part.
http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/24%20hour/t1900%20t1970%20series.aspx
Paragon... | Answered on Aug 15, 2011
Clock motor has gone bad.
I have no source or part number for the clock motor.
Paragon is no longer making timers and parts.
Patriot shows they still sell 1015-00rs for $187
http://www.patriot-supply.com/products/showitem.cfm/55171
http://waterheatertimer.org/Paragon-timers-and-manuals.html#1015
Intermatic crossover shows T1975 is replacement 120V product T1976 for 240V
Clock motors and trippers are made for Intermatic product.
Grainger sell T1975 for $126
http://www.grainger.com/Grainger/INTERMATIC-Indoor-Multi-Operation-Timer-6X761?cm_mmc=GoogleBase-_-Electrical-_-Timers-_-6X761&ci_src=14110944&ci_sku=6X761
At Intermatic
Paragon... | Answered on Jul 05, 2011
I might not understand the problem correctly.
Open following link to identify timer:
From your post, the large dial on your timer can be pushed up and down?
Or are the trippers popping up?
The dial is supposed to rotate clockwise during regular operation, and can be manually rotated either direction to set current time, but dial should not move in and out or up and down.
If the trippers are worn, then they are built in. The problem is that Paragon is no longer making parts and does not support 1015 timers.
It's possible the trippers might be getting pushed up if the on-off mechanism needs lubrication.
May 2011, Patriot stills sells the 1015-00RS for $187
Intermatic 120Volt-480 Volt crossover product is T1975 (advantage is replaceable trippers, motor and switch)
Grainger sells T1975 for $126
Crossover wiring for 120Volt application:
All wires on Paragon 1 to Intermatic Clock
Paragon 2 to Intermatic Com
Paragon 5 to Intermatic NO
If there are wires on Paragon 6 to Intermatic NC
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Paragon... | Answered on May 30, 2011
The Paragon 1015 timer is a 24-hour timer.
The tripper pins or tabs are built into the timer dial.
This timer has NO and NC terminals.
NO NC terminals mean the timer can control two different circuits.
One circuit would be ON when the other circuit is OFF.
When the timer turns on, the circuits change so now one circuit is OFF and the other circuit is ON.
If you have just one circuit, then the following instructions will help you.
If your timer controls two circuits, you can add a comment and I can help further.
OK, your timer controls one circuit.
Locate the tabs on the timer dial.
Push down all the tabs.
Now lift all the tabs for the times you want your Load to turn ON
So if you want the Load to turn ON from 7pm to 5am, then lift all the tabs between those times.
Now when the timer dial rotates, the tripper tabs operate an on-off lever that turns the Load ON and OFF.
Set current time of day
The timer has to be set to current time.
For example it's 6pm.
Grasp and rotate dial until 6pm lines up with the stationary red pointer
Skipper wheel:
The 1015 series has a skipper wheel that lets you skip days of the week.
On these days the timer program will not turn the Load ON or OFF
So if your regular schedule is ON from 7pm to 5am, then the Load will remain OFF for those times.
Set skipper wheel:
Locate day to be skipped on the small dial.
Raise the set screws for the days you want to skip
Raise set screw until it is tight, but do not force
After a power failure, current time of day has to be reset.
If you need more help, add a comment and I will assist.
Paragon... | Answered on May 22, 2011
You posted under Paragon 1015 timer.
Open following link to identify timer and download manual.
Timers are 24 hour, but some have 7-day capability:
Manual says: to set 7-day grasp large 24 hour dial and rotate either direction until correct day of the week appears below Day Set red dot and 12 noon on large 24 hour dial is below red pointer.
To set 24 hour, grasp large 24 hour dial and rotate either direction until correct time appears below red pointer.
Red pointer is stationary at 6:00 position.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Paragon... | Answered on Mar 15, 2011
I think each tab is 15 minutes. If you don't care about a real time clock you could use a dual range plug in timer like a Omron H3CR-F. This has a on time setting and an off time setting
ON- and OFF-times can be set independently and so combinations of long ON- or OFF-time and short OFF- or Ontime settings are possible.
Fourteen time ranges from 0.05 s to 30 h or from 1.2 s to 300 h depending on the model to be used. Thes only have likd 5A contacts so you might have to have the timer operate another realy to control your pump.
Paragon... | Answered on Jul 19, 2010
visit electricalexpeditors.com
we sell replacement parts
leave all info on the contact page
thank you
Paragon... | Answered on Jan 27, 2010
https://www.google.com/search?q=Paragon+Slimline+2&oq=Paragon+Slimline+2&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
Paragon Hardware... | Answered on Nov 07, 2020
That unit is not made any longer. I hope that you have shut off the electricity before you started working on it. You may need to remove the whole motor timer assembly from the housing in order to get the time pointer set back into position
Paragon Hardware... | Answered on Dec 06, 2018
Beverly,
Go here for your MANUAL... SCROLL DOWN 3/4 way for schematics!
https://www.peerlesshouston.com/manuals/8ozpopcorn.pdf
Anthony
(Please SAY "Thank You"!)
Paragon Hardware... | Answered on Jul 09, 2018
Paragon Industries has the manual for the Q11A Kiln on the product page: http://www.paragonweb.com/Q11A.cfm . The direct link to the manual is currently http://www.paragonweb.com/files/manuals/IM-112_E_&_Q_Inst_&_Service_Manual.pdf . The manual covers several models of Paragon kilns.
I hope this helps.
Paragon Hardware... | Answered on Apr 14, 2018
Paragon 1015-00RS Indoor Multi Operation Timer Logo
9 questions posted
Top Paragon Hardware & Accessories Experts
jdthefixer
Marvin
Marvin
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Paragon Hardware & Accessories
Most Popular Question
relay paragon 1015 00rs timer gone
  • Hardware & Accessories
