20 Most Recent Paragon 7007-00 Electromechanical Indoor 7 Day Timer Questions & Answers
Trying to upgrade this to a rainbird. The black is line 1 and 2, I'm not positive about what happens next.
Paragon 7007-00... | Answered on Jul 29, 2020
1) Copy following link:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
http://waterheatertimer.org/images/Paragon-4000-378.jpg
2) 7000 series is same as 4000 series except 7000 series is 7 day, and the stationary pointer on 7000 series is pointed at 9 o'clock position
3) Add a comment and include model and brand timer for clarification.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Paragon 7007-00... | Answered on Feb 13, 2013
Paragon 7007-00 120Volt 7-day timer with 4-NO terminals uses X4299 tripper.
Paragon is no longer making timers and parts, except for defrost timers. 7000 series is not defrost timer.
Patriot supply shows the X4299 tripper for $15 per pair July 2011.
Open following link to identify timer:
Intermatic cross-over timer is T7401B
Paragon 7007-00... | Answered on Jul 14, 2011
Hello, here is a link for the user's manual.
http://portalgb.knowledgebase.net/display/1/index.aspx?c=15121&cpc=XobrEdQ5Lsnv624T2PBS4Exx6S5VyiL7gw3am4YYt6&cid=13013&cat=&catURL=&r=0 .891202986240387
The silver ones (bright) are for closing the contacts. The black (dark) are for opening the contacts.
joe
Paragon 7007-00... | Answered on Jan 21, 2011
Paragon 7007-00 is 120V 7-day timer with spring-wound carry-over for power outage. Indoor outdoor enclosure. Heavy duty terminals and industrial motor. Sounds like it should last many years. Exposure to heat, moisture, dirt might shorten lifespan.
Solutions:
1) Flip manual override. Does it work crisp? If loose or hard to move, then mechanical lever might be worn or dirty. Take timer free and inspect for dirt, rust, loose parts that might indicate if new timer is needed
2) While timer is free from housing, inspect gears. Are they clean?
-Use blower & after gears are clean, spray with WD 40
Note:WD 40 is extremely flammable, turn off power.
3) Pins on timer wheel make contact with lever ... they push lever on and off - add touch of white grease to metal pins where they come into contact with on-off lever. Inspect pins for rough spots that might catch on lever.
4) Clock motor might be bad
Found links showing Paragon 7000 series motor, so motors must be failing. Motor is attached to back of timer.
Robertshaw M3099 120Volt
Robertshaw M3193 240Volt
Paragon 7007-00... | Answered on Sep 30, 2010
I believe this is as close as Intermatic can come. DO you really need the 40Amps? or would 30A work.
http://www.intermatic.com/products/timers/electronic%20time%20switches/7%20day%2030%20amp.aspx
Paragon 7007-00... | Answered on Jul 23, 2010
contact electricalexpeditors.com
Paragon 7007-00... | Answered on May 17, 2010
https://www.google.com/search?q=Paragon+Slimline+2&oq=Paragon+Slimline+2&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
Paragon Hardware... | Answered on Nov 07, 2020
That unit is not made any longer. I hope that you have shut off the electricity before you started working on it. You may need to remove the whole motor timer assembly from the housing in order to get the time pointer set back into position
Paragon Hardware... | Answered on Dec 06, 2018
Paragon 7007-00 Electromechanical Indoor 7 Day Timer Logo
12 questions posted
Top Paragon Hardware & Accessories Experts
jdthefixer
Marvin
Marvin
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Paragon Hardware & Accessories
Most Popular Question
timer falling behind keeping
  • Hardware & Accessories
