20 Most Recent Paragon 4001-0G Defrost Timer Questions & Answers
Add comment and describe timer in detail
Paragon 4000 series timer is replaced by Intermatic T100 series:
http://waterheatertimer.org/Buy-T100-series-timers.html
Paragon defrost timers are shown following link:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Or choose Intermatic defrost timers:
http://waterheatertimer.org/Intermatic-Defrost-timers-and-manuals.html
Gene
j
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Paragon 4001-0G... | Answered on May 19, 2014
Contact Uni-line for replacement clock motor
http://waterheatertimer.org/Paragon-timers-and-manuals.html#42000
Advantage 8025 mechanical timer that gives short time intervals from 1 minute to 27 minutes.
If you are using for septic tank pump, then you have 1 circuit, so you do not need the 8025 to control 3 circuits.
You can install digital timer (EH40 240Volt, or EH10 120Volt) and also get 1 minute intervals.
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html
Paragon 4001-0G... | Answered on Mar 23, 2013
Assuming you have Paragon 4001 40 amp 120Volt timer
By-pass the timer so only pool pump is connected to breaker.
To do this, move wire from terminal 2 and connect to terminal 1.
If breaker no longer trips, then replace timer with Intermatic T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Crossover wiring: Paragon terminal 1 goes to Intermatic terminal 1.
Paragon terminal 2 to Intermatic terminal 2.
Paragon terminal 3 to Intermatic terminal A
If breaker keeps tripping after bypassing timer, then tighten wires on circuit breaker and test again.
If breaker keeps tripping, then move wires to another same-size breaker.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Breakers trip when they sense overheating.
If motor is causing problem, you might need electrician to track down source of overheating.
Paragon 4001-0G... | Answered on Jun 25, 2012
Link below shows Paragon timers
8000 series manual shows 8141-00 is 120Volt:
http://waterheatertimer.org/pdf/8000-series-defrost-sell-sheet.pdf
I am not sure what the suffix b means, and there are always little differences.
The difference could be something simple like knockouts, or mounting bracket.
Wiring and operation should be same since the sell sheet doesn't list 8141-00b as different model.
Paragon 4001-0G... | Answered on Jan 11, 2011
This is a really old timer.
The link below will get you to the owners manual for this timer. Sorry I could not help you better.
http://www.paragontimecontrols.com/manuals/paragon/110-703B.pdf
Paragon 4001-0G... | Answered on Dec 26, 2010
www.electricalexpeditors.com
Paragon 4001-0G... | Answered on Nov 02, 2010
http://www.icca.invensys.com/paragon/P100_series.htm
Click on 'download manual' >> it is a 2-page pdf file, you need adobe reader
Paragon 4001-0G... | Answered on Sep 10, 2010
To set paragon timer: Pull large round dial straight out towards you, then rotate dial until correct time is lined up with stationary 'pointer' on front of dial
Setting Defrost time, Place the start pins(screw pins) in the outer dial, at the time of day- When you want defrost to start. (8am-2pm-8am-2pm) 4 hours min. between hours.
Set the Time of Day, Grasp knob marked - Turn to set. rotate, until the correct time of day. Ever timer there is a power interuption, this will ahve to be re-set.
Depress and rotate the bronze pointer on the inner dial to the length of defrost wanted, - apx 30 minutes.
done.
Paragon 4001-0G... | Answered on Jan 22, 2009
https://www.google.com/search?q=Paragon+Slimline+2&oq=Paragon+Slimline+2&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
Paragon Hardware... | Answered on Nov 07, 2020
That unit is not made any longer. I hope that you have shut off the electricity before you started working on it. You may need to remove the whole motor timer assembly from the housing in order to get the time pointer set back into position
Paragon Hardware... | Answered on Dec 06, 2018
Paragon 4001-0G Defrost Timer Logo
11 questions posted
Top Paragon Hardware & Accessories Experts
jdthefixer
Marvin
Marvin
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Paragon Hardware & Accessories
Most Popular Question
defrost timers 8141 00
  • Hardware & Accessories
