20 Most Recent Polder Traffic Light Kitchen Timer- White Questions & Answers
Reset timer?
1) Copy following links to identify same-similar timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) Add comment and describe timer in detail.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Polder Traffic... | Answered on Dec 18, 2012
you can get a manual from
http://www.fantes.com/thermometers.html
in PDF format.
Please rate this solution. Thanks.
Polder Traffic... | Answered on Jan 02, 2010
https://enlaslejamp.files.wordpress.com/2015/10/polder-clock-timer-instructions.pdf
https://dokumen.tips/documents/polder-clock-timer-manual-polder-clock-timer-manual-product-manual-is-included.html
Polder Hardware... | Answered on Mar 23, 2020
1) Send me a photo of timer so I can possibly identify it and find manual:
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
2) Open following link to identify same-similar timer, and then add a comment which is closest to your timer.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Polder Hardware... | Answered on Apr 03, 2011
Go to
www.polder.com\productinfo.html
That timer is listed
Polder Hardware... | Answered on Jan 03, 2010
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Hardware &... | Answered Yesterday
Polder Traffic Light Kitchen Timer- White Logo
3 questions posted
Top Polder Hardware & Accessories Experts
Gene Haynes
Terry
Terry
Attique-ur-Rehman
Attique-ur-Rehman
Are you a Polder Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Polder Hardware & Accessories
Most Popular Question
am hearing impaired lights timer
  • Hardware & Accessories
