20 Most Recent Cam Spray 25006HT 2500 PSI Cold Water Gas Trailer Mounted Pressure Washer with 6.5 HP Honda Engine Questions & Answers
Your unloader valve is not functioning. Take it apart and make sure it all the parts are able to move freely under the spring. You may need a new o-ring or two if you see damaged ones.
Cam Spray... | Answered on Jul 24, 2013
Though I have never heard of Yellowstone appliances, I am pretty sure there is a way to get replacement parts from the company spare parts department or from other sources who sell these pressure washers. If not, try the Internet, or try the Speed shops where they sell these to people who pressure wash their cars/trucks. I am also sure there are other hoses not necessarily for the Yellowstone brand but fit perfectly well on them. Find out where they sell other brands and take your washer to them, ask them if they can sell you a hose with the right connectors to fit your washer. No salesperson can refuse to sell you a good bargain.
Garden | Answered 3 hours ago
i wouldnt even consider it. a truck mounted plow makes more sense
Garden | Answered Yesterday
We are the original Landa store in Portland, OR and have every Landa manual available both in digital and hard copies. If you can provide a serial number and email address I would be happy to send one of these out to you right away. You can reach me using the information below.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Garden | Answered 2 days ago
Make sure that the nozzle is clean. Also the tube between the nozzle and tank. Check inside the tank to be sure there is not any debris in the tank. Is the pump working and building up pressure? Does the cap O ring make a good seal?
Garden | Answered 3 days ago
This is how to solve the stiff Makita plunge saw easily!!!
I've just carried out the following steps and it's like a new saw.
Clear a table top and grab the following tools:
Philips screw driver
4mm allen key
grease- i used silicone grease
1. Take the base off the saw by removing the 4 x obvious screws.
2. If you look at the saw, you'll see that is pivots on a single pin at the rear. You'll also notice that there is a 4mm allen screw driven into that pin.
3. Remove the 4mm allen screw.
4. Fill the screw hole with grease and drive the 4mm allen screw back in (it'll force grease along the pin internally). Do this 3 or 4 times.
5. Work the mechanism back and forth as if you're plunging the saw- you'll notice that it becomes so much more easy to move.
6. Wipe away the black dirty grease that you have forced out of the pin. Reinsert the 4mm allen screw and tighten
7. refix the base and spring.
8. Job done.
This actually bugged me for ages until i finally decided to have a look and see what the issue was.
Retractable things - hoses and cables and even the mower recoil starter rope are invariably powered by a clockspring.
One end is anchored to the stationary casing and usually the centre is anchored to the rotating part. The spring is pretensioned by an amount sufficient to retract the hose, rope or cable all the way and then pulling out the rope, etc. will further tension the spring. The spring end is usually the part that breaks or the anchor.
The spring should be treated with respect as it is usually a great deal longer than expected and should you dismantle a troublesome unit it is very important to keep a firm hold on it because if they are allowed to unravel it is violent and there is a couple of sharp ends...
When a retractable unit ages it often becomes sluggish and it usually helps to wash and dry the spring and lubricate with a few drops of light machine oil or some graphite dust.
Garden | Answered on Sep 19, 2020
are you letting it warm up ?? if you are the carb needs adjusting or replacement. new gas?? i hope so these are picky
Garden | Answered on Sep 18, 2020
we do not search for parts for anything . that is your job . website is for information only on diy fixing
Garden | Answered on Sep 16, 2020
search google for it. we dont have a library full here.
sorry i can not seem to find anything on that , other then according to a google link mastercraft snow blowers was made by gilson , Gilson is now out of bussiness as far as i know .. i checked searspartsdirect.com and on another site and neither came up with anything ... i can find other brands on sears parts site but guess they dont do the mastercraft brands ... but its weird as they do list mtd parts lists ... i will keep you in mind and see what i can come up with in the next few days and if i find something i will post back on here .. have you checked on ebay and amazon i have found odd stuff like that on there before ... sorry i wasnt much help ... if it was made by by mtd under one of their many names then i can find info on them all day long ..,
Garden | Answered on Sep 15, 2020
Start by putting a automotive test lamp (incandescent
type) in series with the battery and ground cable. It should light and the fuse will remain intact.
Then start push/pulling electric cables and wires while observing test lamp. If there is a short from abrasion or a detached connector likely you'll get the lamp to flicker or go out.
If you cant get the lamp to flicker, you'll need to start disconnecting components to isolate the problem. Start with the ignition switch, but expect the light to go out. If it doesnt then, look to connections at the starter solenoid. Then disconnect engine alternator or voltage regulator. Then the PTO and brake switches.
fixya doesnt sell anything. contact the maker
Garden | Answered on Sep 14, 2020
first check from steering wheel down to gears to see if they are wore,, if not check the rods to each wheel,, hope this help
Garden | Answered on Sep 13, 2020
Cam Spray 25006HT 2500 PSI Cold Water Gas Trailer Mounted Pressure Washer with 6.5 HP Honda Engine Logo
Popular Tags
1 questions posted
Top Cam Spray Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Cam Spray Garden Expert? Answer questions, earn points and help others
View Most Popular
Cam Spray Garden
  • Cam Spray Garden
Most Popular Question
will not release pressure dies
  • Garden
