20 Most Recent
Milwaukee Tool 10" Magnum Compound Miter Saw Questions & Answers
Need to order a replacement guard for my ten inch
Are you talking about the lower guard if so the number is 43-54-0695 and if you will give me an idea where you are located with zip code I will try and find someone close. If you are looking for another guard please let me know and I will get that information for you
Motor on miter saw is runnig back wards
I would suggest going to Milwaukeetool.com and typing in your model number and pulling up a wiring schematic for this tool. If your switch and field are not as shown on this breakdown (its a good one) I would either take it to a repair center or change what is wrong one wire at a time. They also have a toll free number and would be more than willing to help with your problem. Let me know and have a good day. P.S. I would not run the blade backwards though.
Miter saw motor is running back wards
I'd say it was the new wiring that was reversed. Motors cant really start reversing themselves on their own and the only other way it would seem reversed is if the blade was put on backwards...
So yes I think you have the wires reversed when you re-wired the cord.
Please rate this solution on FixYa!
Solution for "changing blades on a milwaukee miter saw
Have you removed the old blade yet?
The blade lock my be broken off -- it should be a button on top of the motor.
This saw has left hand threads -- turn clockwise to loosen the bolt/nut.
If you can't find the blade lock, lower the saw onto a piece of wood llike a 2x4 to keep the blade from turning.
Super Sawzall 6527 just stopped working. I did an
could be a couple things, unplug tool and look at the pins on both the cord and the pin housing to make sure none pushed back, next remove handle half and remote electronic and look for a loose flag terminal at the brush holder, look for loose wires on the switch, (give a gentle tug) and remove the brushes and look for unusual wear patterns and possibly a burnt brush spring. Let me know if you need more help.
