20 Most Recent Samsung AW0893L Air Conditioner Questions & Answers
My aw0893l air conditioner does not get cold. do i need freon?
Well first off is the compressor running? When you turn on the unit the fan will start. Turn the unit on to fan only. Then turn it into the cooling mode do you hear something else start? That would be the compressor. Remove the front panel so you can see the cooling coil (evaporator ) if it is freezing and has frost on just part of the coil top or bottom you have lost Freon or a system restriction.. One of the major problems with air cons is a very dirty or plugged condenser coil, which is the outside coil. If you have cotton wood trees in your area this is probably the problem. Hope this helps Lynn
5/29/2014 2:08:00 AM • Samsung AW0893L... • Answered on May 29, 2014
tip
Good day,<br /><br />If you have the above mentioned air conditioner and you are having problems with it please follow the provided link to download the service manual.<br /><br />With the service manual you will be able to find common problems and solutions to that problems. All you have to do is follow the link and download the manual.<br /><a href="http://appliancedigest.com/index.php?/files/file/526-sam0004-samsung-room-air-conditioner-service-manual/"><br />Link to download the manual</a><br /><br />I sincerely hope that by posting the link to the manual it will be helpful in some way or another.<br /><br />Have a wonderful day!<br /><br />Kind regards
Leaking water
mcdevito75 here, The portion of the a/c unit that goes outside the window is the evaporator and suppose to leak water, check the drain hole in the unit floor on the outside portion of the unit, reach this drain hole thru another window or have your local a/c repair shop look at it, they come to the house.
6/24/2010 1:19:40 AM • Samsung AW0893L... • Answered on Jun 24, 2010
Samsung split ac c1 error
C1 error solve solution
10/14/2022 9:08:28 AM • Samsung Heating... • Answered on Oct 14, 2022
Samsung AQ12FAN, indoor unit starts on it's own, and stops after a few seconds.
Hi, It could be that the motor for the device needs to "warm up". Everytime it stops the internal thermostat sees that the target temperature has not been reached so it starts the internal motor again. This happens in a cycle until the motor gets warmed up or the target temperature is reached. This is my hypothesis. So, you might need to get the devices's motor checked out. Thank you.
8/7/2022 12:00:27 PM • Samsung Heating... • Answered on Aug 07, 2022
2answers
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
6/4/2022 11:14:59 AM • Samsung Heating... • Answered on Jun 04, 2022
My Samsung AQ12UGQN Split Unit heating has all 3 lights flashing green!
Either the new control board is faulty, or the connections are bad, or the issue is somewhere else. The main problem is that you are not an air conditioning / heating engineer. Some things are not home owner fixable.
3/18/2022 8:02:46 PM • Samsung Heating... • Answered on Mar 18, 2022
What does E5 59 means in Samsung aircon?
My multi head ducted system is showing E559 what does it mean ?
1/18/2022 3:43:46 AM • Samsung Heating... • Answered on Jan 18, 2022
2answers
AIR conditioner samsung aqv12a error message "E101
ErrorCode = 101Explanation and Checking points = Indoor unit communication error - checkwiring
10/8/2021 4:10:02 PM • Samsung Heating... • Answered on Oct 08, 2021
2answers
How do I turn off the beep of the remote?
I will tell u the exact answer, press the 2nd F button and agin press the beep off button and do same for on off beep. It will on and off ur beep of remote.
7/3/2021 9:03:00 PM • Samsung Heating... • Answered on Jul 03, 2021
Samsung A/C remote #DB93-03012K. How to change from centigrade to fahrenheit?
Better to learn Centigrade as it it so simple. 0' is freezing point of water, 100' is boiling, your home needs to18'C Details here! https://www.google.com/search?q=Samsung+A%2FC+remote+%23DB93-03012K.+How+to+change+from+centigrade+to+fahrenheit ..
6/30/2021 3:41:59 AM • Samsung Heating... • Answered on Jun 30, 2021
I have a brada ac model # ky25/b and the temps are
pressing the (+ and -) temperature adjustment buttons at the same time for 2 seconds will lock the controls. Pressing the buttons at the same time again will unlock the controls.
6/27/2021 8:28:07 PM • Samsung Heating... • Answered on Jun 27, 2021
Samsung Air Conditioner. What does error codes mean? E 101 and A 255 code
All FIXYA questions MUST have make model (what it is) This appears to be a Samsung Air Conditioner? I have moved you from Cars and Trucks, and FIXED your Question! https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk01oIaILRRZkKWpSw__ZIb_xruN8Tw%3A1615332888677&ei=GAZIYPLgKOiE_Qbt15nIAg&q=Samsung+AC+E+101+and+A+255+code ..
3/9/2021 11:39:18 PM • Samsung Heating... • Answered on Mar 09, 2021
Samsung AQV12VBA error cod displayed E5 54
Check the freon...
11/8/2020 7:30:35 AM • Samsung Heating... • Answered on Nov 08, 2020
2answers
How to repair Samsung AQV 12 FAN Air Conditioner
You can turn off the Thermostat, and the powers switch on the furnance and turn the breaker off in the breaker box wait about 20 - 30 minutes and turn the breaker back on, and the power to the furance back on and the thermostat, this should reset the system.
Melvin
St Louis
7/18/2020 12:39:40 PM • Samsung Heating... • Answered on Jul 18, 2020
Samsung air conditioner Error E468
Possible manual, depending upon model which has not be provided in your posting. https://www.manualslib.com/manual/1626579/Samsung-Am053fxmdch.html?page=56 Other web sites simply state "current sensor error" without explanation. You may need to pay professional repair, or purchase a replacement air conditioner.
7/7/2020 10:16:00 PM • Samsung Heating... • Answered on Jul 07, 2020
Samsung celling cassette AC indoor light green blinking AC off what problem
My Samsung cassette air conditioners showing green light instead of blue what it's meant
5/25/2020 4:55:32 AM • Samsung Heating... • Answered on May 25, 2020
Samsung split unit yellow on out door unit flashes and ac not turning on
Count the number of flashes between the pauses and let us know
4/6/2020 6:46:17 PM • Samsung Heating... • Answered on Apr 06, 2020
Samsung AW0893L Air Conditioner Logo
Popular Tags
3 questions posted
Top Samsung Heating & Cooling Experts
Marvin
Marvin
jws1013
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Heating & Cooling
Most Popular Question
aw0893l air conditioner not get cold
  • Heating & Cooling
