20 Most Recent Samsung AW1803M Air Conditioner Questions & Answers
UNIT SHOT CYCLES. COMPRESSOR ONLY RUNS ABOUT 3-5
Unit is most likely low on charge or the freeze sensor is bad...
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
6/11/2011 2:14:37 AM • Samsung AW1803M... • Answered on Jun 11, 2011
Window A/C - no apparent drain holes for the condensate tray ?
On most new units, the water left in the tray is picked
up by the fan motor blade which kind of cools the unit down.
On some models there is a round hole on the bottom left hand corner on the back of the unit. Really hard to
get a fitting between condensor coil and frame,but it
can be done. However the manufactuer will usually state if a drain has to be run if it is needed
6/30/2010 2:27:44 AM • Samsung AW1803M... • Answered on Jun 30, 2010
Samsung split ac c1 error
C1 error solve solution
10/14/2022 9:08:28 AM • Samsung Heating... • Answered on Oct 14, 2022
Samsung AQ12FAN, indoor unit starts on it's own, and stops after a few seconds.
Hi, It could be that the motor for the device needs to "warm up". Everytime it stops the internal thermostat sees that the target temperature has not been reached so it starts the internal motor again. This happens in a cycle until the motor gets warmed up or the target temperature is reached. This is my hypothesis. So, you might need to get the devices's motor checked out. Thank you.
8/7/2022 12:00:27 PM • Samsung Heating... • Answered on Aug 07, 2022
2answers
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
6/4/2022 11:14:59 AM • Samsung Heating... • Answered on Jun 04, 2022
My Samsung AQ12UGQN Split Unit heating has all 3 lights flashing green!
Either the new control board is faulty, or the connections are bad, or the issue is somewhere else. The main problem is that you are not an air conditioning / heating engineer. Some things are not home owner fixable.
3/18/2022 8:02:46 PM • Samsung Heating... • Answered on Mar 18, 2022
What does E5 59 means in Samsung aircon?
My multi head ducted system is showing E559 what does it mean ?
1/18/2022 3:43:46 AM • Samsung Heating... • Answered on Jan 18, 2022
2answers
AIR conditioner samsung aqv12a error message "E101
ErrorCode = 101Explanation and Checking points = Indoor unit communication error - checkwiring
10/8/2021 4:10:02 PM • Samsung Heating... • Answered on Oct 08, 2021
2answers
How do I turn off the beep of the remote?
I will tell u the exact answer, press the 2nd F button and agin press the beep off button and do same for on off beep. It will on and off ur beep of remote.
7/3/2021 9:03:00 PM • Samsung Heating... • Answered on Jul 03, 2021
Samsung A/C remote #DB93-03012K. How to change from centigrade to fahrenheit?
Better to learn Centigrade as it it so simple. 0' is freezing point of water, 100' is boiling, your home needs to18'C Details here! https://www.google.com/search?q=Samsung+A%2FC+remote+%23DB93-03012K.+How+to+change+from+centigrade+to+fahrenheit ..
6/30/2021 3:41:59 AM • Samsung Heating... • Answered on Jun 30, 2021
I have a brada ac model # ky25/b and the temps are
pressing the (+ and -) temperature adjustment buttons at the same time for 2 seconds will lock the controls. Pressing the buttons at the same time again will unlock the controls.
6/27/2021 8:28:07 PM • Samsung Heating... • Answered on Jun 27, 2021
Samsung Air Conditioner. What does error codes mean? E 101 and A 255 code
All FIXYA questions MUST have make model (what it is) This appears to be a Samsung Air Conditioner? I have moved you from Cars and Trucks, and FIXED your Question! https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk01oIaILRRZkKWpSw__ZIb_xruN8Tw%3A1615332888677&ei=GAZIYPLgKOiE_Qbt15nIAg&q=Samsung+AC+E+101+and+A+255+code ..
3/9/2021 11:39:18 PM • Samsung Heating... • Answered on Mar 09, 2021
Samsung AQV12VBA error cod displayed E5 54
Check the freon...
11/8/2020 7:30:35 AM • Samsung Heating... • Answered on Nov 08, 2020
2answers
How to repair Samsung AQV 12 FAN Air Conditioner
You can turn off the Thermostat, and the powers switch on the furnance and turn the breaker off in the breaker box wait about 20 - 30 minutes and turn the breaker back on, and the power to the furance back on and the thermostat, this should reset the system.
Melvin
St Louis
7/18/2020 12:39:40 PM • Samsung Heating... • Answered on Jul 18, 2020
Samsung air conditioner Error E468
Possible manual, depending upon model which has not be provided in your posting. https://www.manualslib.com/manual/1626579/Samsung-Am053fxmdch.html?page=56 Other web sites simply state "current sensor error" without explanation. You may need to pay professional repair, or purchase a replacement air conditioner.
7/7/2020 10:16:00 PM • Samsung Heating... • Answered on Jul 07, 2020
Samsung celling cassette AC indoor light green blinking AC off what problem
My Samsung cassette air conditioners showing green light instead of blue what it's meant
5/25/2020 4:55:32 AM • Samsung Heating... • Answered on May 25, 2020
Samsung split unit yellow on out door unit flashes and ac not turning on
Count the number of flashes between the pauses and let us know
4/6/2020 6:46:17 PM • Samsung Heating... • Answered on Apr 06, 2020
Samsung AW1803M Air Conditioner Logo
2 questions posted
Top Samsung Heating & Cooling Experts
Marvin
Marvin
jws1013
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Heating & Cooling
Most Popular Question
unit shot cycles compressor only runs
  • Heating & Cooling
