20 Most Recent
Runco CL-410 Multimedia Projector Questions & Answers
Projector shut off
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video. Pretty easy fix.
Runco CL710 projector. Had power outage and
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video for this.
My Runco CL-410 projector runs
Look inside the lamp. If you look into it if you see any white build up at its base, replace it. Need help, let me know.
I have a Runco CL410
Sounds like it may have some dust build up. Do you know how to open the case and clean out?
I have no power to
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video. This is an easy repair.
