20 Most Recent
Nebo Redline Tactical Flashlight Strobe S.O.S 220 Lumen 5581 Questions & Answers
Nebo pal shuts off after 10 seconds
it looks like the power bank might be running low on power if the flash light portion of it shuts down after 10 seconds. You need to recharge the device or find a new power source while the device recharges.
Thank you.
How do you take apart the charger for an Nebo Torchy 2K flashlight
as a general precaution, disassembling an electronic device like a charger can be dangerous and may cause harm to the user or the device itself. It's always recommended to refer to the manufacturer's instructions or seek the assistance of a qualified technician to avoid any potential hazards or damage to the device.
Nebo SLyde King work light will not turn off even when shut.
If your Nebo SLYDE King work light is not turning off even when shut, there may be a few possible reasons for this:
- Batteries: Check the batteries to see if they are fully charged and properly installed. Low battery power or a loose battery connection may cause the light to stay on even when switched off.
- Faulty switch: There may be an issue with the switch itself. If the switch is stuck or broken, it may be keeping the light on. Try gently pressing and releasing the switch a few times to see if this fixes the problem.
- Electrical problem: There may be an electrical problem with the light, such as a short circuit or damaged wiring. In this case, it is best to stop using the light immediately and seek professional help from a qualified electrician or an authorized service center.
- Reset: Try resetting the light by removing the batteries and leaving them out for a few minutes. Then reinstall the batteries and try turning on and off the light again.
If none of these steps work, it is recommended that you contact the manufacturer's customer service for further assistance or bring the light to an authorized service center for repair
