20 Most Recent Gestetner A045 Wide Format Copier Questions & Answers
on the right side
Gestetner A045... | Answered on Nov 27, 2013
if you search google for the plotter model and it will let you download a windows 7 driver cos i just looked and there is one, try this:
http://www.driverplatform.com/file_a045.html
Gestetner A045... | Answered on Feb 14, 2013
I know it is a bit late but my company had the same problem just a few weeks ago and I figured out a work around that might help.
First of all, we have a computer dedicated to our Savin 2400 that still runs XP. I found this
http://www.howtogeek.com/howto/33088/print-files-from-anywhere-via-any-device-with-dropbox/
which allows you to set up a dropbox and has a .vbs script that is set to auto print.
From there it was easy, just go out and download a pdf image writer like this one
http://www.pdfill.com/freewriter.html
or any other document writer and set the default folder it saves to in the dropbox print queue. This will let you hit print, select your document writer (which you can rename to "ricoh") and print away!
Gestetner A045... | Answered on Feb 04, 2012
Your Gestetner A045 is made by Ricoh. I will be a lot easier finding a Ricoh dealer than a Gestetner one. Here are the equivalent models for your machine. That is, any dealer listing that they service Ricoh, Savin, Lanier or Gestetner should be able to service it.
Your machine is the same as:
Ricoh Aficio 240W
Savin 2400WD
Lanier LW310
Good Luck and Thank You for using Fixya.
WheatlandServices
Gestetner A045... | Answered on Feb 02, 2012
Go to this web site http://www.ricoh-support.com/ and see if there is what you want.
The equivalent model is Aficio 240W.
Go to the quick search and in the left tab scroll to the wide format an in the right tab select the model (240W).
See you!
Gestetner A045... | Answered on Jul 20, 2011
the pc you have installed the plot server should be login as local admin
Gestetner A045... | Answered on Jun 18, 2011
make the reader option is enabled in the server application
there should be 4 applications running
Gestetner A045... | Answered on Jan 30, 2011
When you select the user or the path for the folder you can view it on the screen. Simply type in your PC the path to see where you are sending.
On your PC click the start button, then RUN. Write the Path you see in the machine. At last ENTER
Hope this helps!!!!!!!!!!!!!!!!!!!!
reply any questions ok?!
Gestetner A045... | Answered on Jan 25, 2011
YOU CAN GO TO WWW.PRESICIONROLLERS.COM AND TO GET DISCOUNT, YOU HAVE TO REGISTERED AS DEALER OR COPIER TECHNICAL MAN
Gestetner A045... | Answered on Apr 16, 2010
change toner... if that doesn't fix it then change the drum...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Gestetner A045... | Answered on Dec 24, 2009
scantools is installed with plotbase.
are u able to print?
if not , u need to install the full software .
(hope u have the serial no.-- on the interface card in the pc)
Gestetner A045... | Answered on Oct 15, 2009
A045 RW-240 SCANTOOL Free Swoftwair
Gestetner A045... | Answered on Oct 07, 2009
This requirement and solution are in the Plotbase manual, not the copier manual. See pp. 29-30 Setting for RW-240 ScanTool.
1. Start - Control Panel - Administrative Tools
2. Local Security Policy
3. Local Admin Policies
4. User Right Assignments
5. Lock Pages in Memory - Local Security Setting
4. Add User or Group, then Advanced
5. Add or Find Now - select users (all)
6. OK
7. close Local Security Setting windows
Gestetner A045... | Answered on Aug 31, 2009
If you are changing a paper roll, make sure you can advance the paper through the "throat" using the green knob and then manually trim it. If you are loading paper in the cassette tray, make sure you adjust the green sizing guides to match the paper dimension (8.5x11", 11x17), etc.
33 questions posted
Top Gestetner Office Equipment & Supplies Experts
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Gestetner Office Equipment & Supplies
Most Popular Question
any rw 240 drivers available windows 7
  • Office Equipment & Supplies
