20 Most Recent
Hasbro Interactive Candy Land Adventure for Windows, Mac Questions & Answers
I cant get candyland to play, i installed it twice
Ok go to your control panel and go to the add or remove programs icon...you may have to look hard for it...if you find it and you see it on the computer but its still not allowing her to play it...click on candyland and there should be a option above it to uninstall...once uninstalled restart the computer and start from scratch put the discs in and do what it prompts you to do ...now eject the disc once the download is finished and then put the disc back in the computer...there should be a AUTO play..... if it doesnt come up right away go to my computer and hit the drive that has her cd in it and that should make it pop up then
3/17/2010 4:02:30 AM •
Hasbro...
Answered
on Mar 17, 2010
Zoo tycoon can't load/save games
Unfortunately running an older game like this, you will have issues. Make sure you have the latest updates installed. If that doesn't resolve the issue you may not be able to save under windows 7. I would try compatibility for windows 98 before I give up all hope though.
4/10/2014 5:40:58 PM •
Hasbro...
Answered
on Apr 10, 2014
I have windows 7 and
You need to read the case that the CD came in. It will list 'system requirements". I bet that the game is written in 32 or 16 bit language and windows 7 is 64 bit and it is not "backwards" compatible, meaning that it won't run a 16 or 32 bit program.
5/5/2011 1:48:43 PM •
Hasbro...
Answered
on May 05, 2011
I can not install Boggle on a Vista system
You could try to rightclick the setup.exe, select properties, go to compatibility and run it in Win95 compatibility. You can also try to make a shortcut to the game, then doing the above. There could also be a map called DIrectX on the disk. Try opening the executable in there, install DirectX, then try the game again.
Otherwise you're out of luck. Microsoft doesn't support old games, gets you to buy new ones. I don't like it either, but there's nothing you can do about it but switch back to Win95
12/9/2009 8:15:57 AM •
Hasbro...
Answered
on Dec 09, 2009
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information.
If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
Solitaire Customer Service Call 1-8O5-225-6690
We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
