20 Most Recent
Gestetner - 5502 Digital Imaging System Copier Questions & Answers
Looking for codes sc360 and sc990 gestetner 5502
sc360 is a hard drive detection error. The hard drive might be either defective or disconnected, or one of the connectors might be loose. If you know the hard drive is good, check its power and data cables and connectors. In rare cases, this error can point to a faulty BICU board.
sc990 is a general software error. This error is often logged in conjunction with other errors, and may not necessarily represent a separate problem.
Your best bet is to check the hard drive first -- maybe try formatting it or replacing it if you have an extra one. Good luck!
Gestetner - 5502...
Answered
on Oct 08, 2011
Am posting again. I stripped off gestetner MP2501L 8 times due to problem ' see instructions on right side to solve' but same. No paper inside. What is the actual problem.
Hello Christopher
Are you in the Philippines? I notice that your copier has changed from Ricoh to Gestetner? We are a North American website.
This is a commercial office machine, and from my experience of them is that on the right side you will see on the inside, a list of instructions for where to check for obstructions. It seems you have already done this 8 times! Frustrating! Try this;
Open the right side cover, unlatch all the bits at that side.
Open the straight pass door on the left side.
remove ALL the paper drawers.
Get a powerful flashlight, look in all the spaces you have just created, especially at the edges of drawers and paper pathways. You are looking for a tiny piece of paper that one of your employees carelessly left behind after a paper jam.The one I found was right at the back of the straight pass door. When a sensor is covered, it creates that message.
If that fails, Ricoh will have to come and attach their Laptop scan software to it which will tell which sensor is obstructed or has failed.
Gestetner Office...
Answered
on Jan 14, 2021
Sc 569 for ricoh mp 5500
sc 569 is the pressure roller contact sensor error Troubleshooting Procedures:
1. Check or replace the harness of the pressure roller contact sensor.
2. Replace the pressure roller contact sensor.
3. Replace the pressure roller contact motor
Gestetner Office...
Answered
on Jun 02, 2019
SC 569 Error code in MP 5500
Gestetner Office...
Answered
on Jun 02, 2019
