20 Most Recent Gestetner - DSm675sp Digital Imaging System with Scan - Print Copier Questions & Answers
This problem occur due the DF is not detecting the Orginal size.
Check the Size detection sensor,located when u open the ADF cover u can see, Clean the sensor by blowing.
Gestetner -... | Answered on Jul 19, 2012
See pages 3-2 (136/153) and 4-2 (140/153) of the Service Manual:
http://empresasolympia.com/manual/DX2330.pdf
Gestetner Office... | Answered on Jan 14, 2020
Clamper error The MPU cannot detect the clamper position sensor signal ( open or closed) within 3.0 seconds after the clamper
Gestetner Office... | Answered on Dec 02, 2019
i m gatting a E-00 error code geststner dx2430
Gestetner Office... | Answered on Jun 04, 2019
sc 569 is the pressure roller contact sensor error Troubleshooting Procedures:
1. Check or replace the harness of the pressure roller contact sensor.
2. Replace the pressure roller contact sensor.
3. Replace the pressure roller contact motor
Gestetner Office... | Answered on Jun 02, 2019
Troubleshooting Procedures: 1. Check or replace the harness of the pressure roller contact sensor.
Sc 547 is Zero cross error
Troubleshooting :
1. Check the power supply source.
2. Replace the +24V fuse on the PSU.
3. Replace the PSU ( power supply unit)
Sc 547 is Zero cross error Troubleshooting :
1. Check the power supply source. 2. Replace the +24V fuse on the PSU.
password word can be reset in special SP mode as follows:
Reset, 1,4,3 press C then hold C
special SP mode, go to SP direct 5-846-046
This will rest the Admin password to default
password word can be reset in special SP mode as follows: Reset, 1,4,3 press C then hold C special SP mode, go to SP direct 5-846-046 This will rest the Admin password to default
Hi Hope this helps.The metal gauze filter (see image) behind the input nipple on the drum unit may become blocked with congealed ink deposits causing the ink not to feed at full flow.
Strip and clean the blocked gauze filter in the Ink Supply System.
Gestetner Office... | Answered on Apr 29, 2019
The ID sensors are dirty or transfer belt unit is damaged/dirty/faulty. The ID sensors are below the fusing unit facing down onto the belt. Usually best to remove the fuser unit and the belt unit to get to them with a short brush or unscrew to remove them but be very careful not to damage the transfer belt!
Gestetner Office... | Answered on Apr 15, 2019
Description. Cutter error The cutter HP sensor does not turn on within 3.0 seconds after the cutter motor turns on
Your master cutter is jammed clean the Master cutter
Gestetner Office... | Answered on Apr 14, 2019
Ink pump motor may be not working first you need check your cp is original.. After that remove drum unit disabled the unit and clean ink detection sensor and ink pump motor
E02
Paper Table Drive Failure.The paper height sensor or the table lower limit sensor does not turn on within 7 seconds after the table drive motor turns on. point to check-
Paper table drive motor Paper height sensor or table lower limit sensor. Mechanical interference with the paper table drive
Gestetner Office... | Answered on Mar 10, 2019
1 questions posted
Top Gestetner Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Gestetner Office Equipment & Supplies
Most Popular Question
paper getting jammed in document feeder
  • Office Equipment & Supplies
