20 Most Recent
Atari Chris Sawyers Locomotion for Windows Questions & Answers
Unable to intialize graphics system
Its quite an old game, Step one is running it in Compatibility mode. Try xp.
Other then actually getting into the game files and editing what needs to be updated for it to run on Direct X 11, well... Good luck with that.
Autoplay wont load the game
Open Windows Explorer and use notepad to see which executable program it is trying to invoke. You can manually open it as a workaround.
Will it work on windows 7
Dear,
it has been reported by many users that this game is correctly running on Windows 7 without any hack or smth.
BTW if problems may happen, there's also a feature called "XP mode" supported in Win 7 Ulti, which should ensure alost 100% compatibility with XP
Please rate my solution ++++ if it was helpful, or feel free to ask for more information.
Thank you
Peter_Rei
I have lost the installation code for Chris
Simple answer, No. When you purchase this game, the installation code is yours and is only to be used for one device at a time. There certainly are website out there that will try to market cracks or code generators but mostly these websites are LOADED with viruses and will try to scam you or load your computer with spyware. BEWARE!
Best idea: Use
THIS EBAY SEARCH and re-purchase the game for under $5.00.... How's that?!
Retro Gamestick need help?
To emulate Amiga buttons on your X2 Plus Game Stick Retro Console, you can use an emulator like Amiberry or lr-puae . Here are the steps to emulate Amiga buttons on your X2 Plus Game Stick Retro Console using Amiberry:
Install Amiberry on your X2 Plus Game Stick Retro Console by following the official installation guide .
Download the WHDLoad packages for Amiga games you want to play .
Place the WHDLoad packages in /home/pi/RetroPie/roms/amiga/.
Configure your controller by following the official controller configuration guide .
Launch Amiberry and select the game you want to play .
If you prefer to use lr-puae, you can install it from the optional section of the RetroPie-Setup Script . Once installed, you can place your desired Kickstart ROMs in /home/pi/RetroPie/BIOS/ and use disk and WHDLoad games with this core .
Amiga - RetroPie Docs
TikTok - Make Your Day
Amiga Gotek: Getting started guide ' Installation ' Set up and Game downloads (FlashFloppy) - Retro32
Atari flashback 9 gold wont start get error message
I'm using the same SD card I did with the portable. I didn't have to change the file names for the games. The console recognized them. The save slots also work with the roms in the SD card, which is really neat.see: https:https://sarkariresult.onl/ , https://pnrstatus.vip/ & https://19216811.cam/
