20 Most Recent
BOBKONA Manhanttan Reversible Microfiber 3-piece Sectional Sofa With Questions & Answers
May i wash it? the dog threw up on it
yes its that material on the underside of the cushion thats questionable right? its seems very rippable just looking at it i did it- and when need be still do as i write as a matter of fact a set is in the dryer on the lightest shortest dry cycle i i was looking to see if there were alternate covers i can get off all the seat cushions like i was gingerly peeling a banana evenly - when the cover was finally peeled off it was perfectly inside out, however the back pillows are instigators of mighty stress of strength . the zipper lengths didnt equate to what is inside they must have put the stuffing in first then sewed it together - leaving an opportunity for possibility for someone to open it or get it out or disengage the 2 2 of my stuffing cover casing ripped tryind to get that square peg of the round hole. wait till you try to get those back in also the back pillows are none the same size all vary in an inch or 2 length wise is the concern cause youll be pushing while trying to get that stretch limo in the garage with door closed youll also have to tread lightly with that cloth material thats whats holding not only the stuffing grouped, but that is also what holds and gives the back pillows that shape, saying all hell and going for the stuff that just gets it all back in so you can cross that finish line of a zipper. will look like a sack of potatoes albeit more rounder and fuller than before and upon realization more comfortable and plusher and that nightmare of a material that holds the whole shape of you is the very same material as the other black cloth on the couch inside that is a fluffier version of cotton balls and they dont take any shape in the pillow if that sheath of a stuffing cover is not in tact ..... wash in warm/cold no fabric softeners, dryer sheets or things that specifically boost fragrance. i wash the pillow covers with the pillow covers in case something changed, it wouldnt be mis-moshed and still maintain some form of symmetry if something salvageable happened and it did, the pillows had a new look like a textured suede- the material itself is unchanged and fine but still is just has different umph. while the cushion covers ( dressed back the same the process i was undressing but backwards (like putting a sock on in the style of rolling the socks down on your hands so your thumbs reach the toe area and you out your toes in where your thumbs are holding and pull to unravel ) like that they are without hitch (from inside out to right side out along the way back on the same way because from that initial back pillow debacle was an experience i will never forget. i do wash them if the couch facade gets out of hand my pillows are just comfy and because exact form was lost on the first date their symmetry now lays in the form of the pattern of the material the cushions however they stay stout ironed formed even though as opposed to the cotton balls for pillows the cushions are stuffed with the stunt double of cotton candy because of that it gets boundlessly caught in the zipper and it wont zip i got a tiny gauge allen key and put it through the zippers hole and T' pulled with ease i had to then put my hand on the inside track traveling with my zippering hand to guard further trespass of the zipper in hind sight when my pillows had distinct shape if i had done the cushions first before the pillows i may have had a different experience than that life event of that task with the pillows. I learned real quick with the cushions undressing and dressing them is to work from corner nearest you then move on the too corner nearest that corner and operate in that function its all about the corners with the cushions ( the L shaped cushion when your struggling against the cotton candy invasion, while the zippers legs are 3 inches apart and your pulling to zip them together while working on that curve straddle it sideways and squeeze your thighs together ......the pillows however good luck getting in to even get to one.
1/8/2013 4:19:15 PM •
BOBKONA...
Answered
on Jan 08, 2013
I have a simmons nuflex bed that is fine except the foot wont raise. Massage works on foot, but it just wont lift. No clicking or noises when using the remote
If the foot of your Simmons Nuflex bed will not raise, there may be an issue with the motor or the lift mechanism. Here are a few things you can try to fix the problem:
- Check the remote control: Make sure the remote is properly functioning and the batteries are not dead. Also, check that the foot lift button is not stuck.
- Check the wiring: Check the wiring between the remote, the lift mechanism, and the motor for any frayed or disconnected wires. If you find any damaged wires, they will need to be repaired or replaced.
- Check the lift mechanism: Inspect the lift mechanism and look for any visible damage or debris that may be preventing the foot from raising. Clean the lift mechanism and lubricate it with light oil.
- Check the motor: If the motor is not functioning properly, it may be preventing the foot from raising. If the motor is faulty, it will need to be replaced.
If you are not comfortable with these steps, or if the issue persists after trying them, it may be best to contact Simmons customer support or a professional technician for further assistance. They may ask you to provide your bed's serial number and other information to help troubleshoot the problem.
4/17/2024 2:20:33 AM •
Furniture
Answered
Yesterday
What is the best wine cooler in the market?
The NewAir AW-210ED is by far the most successful wine cooler
there is making the best wine cooler overall for the price. The only downfall
is that this specific model doesn't have the highest capacity for the price.
3/27/2024 2:23:42 PM •
Furniture
Answered
on Mar 27, 2024
Which brand provides the best wine coolers?
I don't know but if I needed to find out I would look first at the brands used by commercial establishments that buy for long life and reliability.
While it is fashionable for wine to be overcooled, my father's words often come back to me, "if a drink has to be chilled to taste good, it is poor quality".
White wines and pale beers are traditionally kept in a cellar.
Cellar temperatures are between 45 and 54 F; comparatively mild temperatures that for most of the year in the temperate regions no refrigeration is needed...
3/27/2024 2:20:04 PM •
Furniture
Answered
on Mar 27, 2024
How long can you keeo sherry cooking wine?
Though sherry tends not to spoil in the traditional sense, this fortified wine actually does have a shelf life. Most types of sherry can be kept unopened for up to three years, however Pale Cream sherries have a shelf life of two years, and Fino and Manzanillo sherries have a shelf life of no more than 18 months.
3/27/2024 2:13:44 PM •
Furniture
Answered
on Mar 27, 2024
What are the advantages of buying a sofa bed?
Sofa
beds are a great solution if you don't have a spare room for guests and want
the option of having people to stay over. During the day it can function as a
couch and at night turn into a bed.
3/24/2024 12:25:41 PM •
Furniture
Answered
on Mar 24, 2024
How do I get the right furniture for my event in London?
The best thing you can do is turn to a company that provides event rentals. I have worked in the industry for years and have always found that renting is easier than buying. Buying means storing the stuff, keeping it in good condition, and ensuring it always matches your event's theme. With an event company in London, you can choose what you need as each event requires.
Some great choices for a company can help you get your hands on the furniture you need, including
Velvet Living. Leave the buying to the event companies; you can just rent what you require, so you never have to worry about storing the equipment or adjusting themes and event settings to suit your available furniture.
3/7/2024 12:06:20 PM •
Furniture
Answered
on Mar 07, 2024
