20 Most Recent
Motorola Mobility L71 Cellular Phone Questions & Answers
Can i transfer sms text
hi
if they give any software package for this phone.then there will be some option for storing the text message in to your pc.you can verify it in manual or by contact the mobile operator.
thank you
6/2/2015 10:05:22 AM •
Motorola...
Answered
on Jun 02, 2015
The screen olways turn white
Initially you have to flash your mobile. update its firmware and then try. If firmware up gradation doesn't work then this can be the issue with LCD itself.best of luck!
3/10/2012 6:48:40 PM •
Motorola...
Answered
on Mar 10, 2012
Where can I download themes and games for this uni...
are downloading straight to cell (you need a data plan from your carrier, go to download and games) this will cost $ depending the size of theme/games and time it takes to complete.....okay #2 this way is using a laptop/pc you will need a usb cable (to fit pc) to a mini usb (compatible to your cell), go to site you wish to download game / theme download to pc........then connect cell to pc via usb go to my computer open cell...copy / paste (make sure any games downloaded is placed in the games folder on cell, themes placed in themes..
try this site also
8/6/2010 5:15:49 PM •
Motorola...
Answered
on Aug 06, 2010
Changing to capital letters in texts.
i might be wrong on this one, but all motorola's are mostly the same on texting. Soto get a capital letter in text just press the 0 before the letter
5/21/2009 2:10:32 PM •
Motorola...
Answered
on May 21, 2009
How to download a themes in mya motorola L71?
To install themes on your l7 you will first have to download skinman and p2k drivers try the latest one (you can search for these softwares in google) In your phone change the default USB settings as data & fax connection then connect your phone to a usb port to which you had never conected your phone before then you will get a message that a new hardware is found select to "install now" then select "Install from a specific location" tick the "include this location in search" click "briowse" and select the p2k drivers folder that you had downloaded. For example "D:\Motorola System\p2kdrivers_2.9" Then click "next". It will install your phone. Then again you will get the same kind of message do the same for all until it says your phone has been installed and is ready for use. Now you have done half of the job. Now run Skinman the file list will be loaded. select install.You will get a message just select ok then browse and find the theme that you want to install then select open the theme will start installing. once you have added the desired number of themes select restart phone. now you are done.
3/30/2009 6:17:19 PM •
Motorola...
Answered
on Mar 30, 2009
I can't turn on my motorola L71 cellphone
You will have to flash your mobile its the only way you can fix it.
For detailed information about how to flash go to www.modmymoto.com.in that click guides then your mobile model number.then select flashing & flexing. There you can find other things also that you can do to your mobile.
3/25/2009 7:51:59 PM •
Motorola...
Answered
on Mar 25, 2009
Sim Network Unlock Pin Motorola
How to enter my Unlock Code on Motorola ?
Model : All Motorola
1 - Switch ON your phone with a not allowed SIM Card,
2 - Phone show "Enter Special Code",
3 - You can now enter the Unlock Code we send to you.
WARNING : If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody allready enter too many wrong codes, you just have to let phone ON on theses errors messages and after 40 min to 2 hours maximum the message "Enter Code Special" will appear again !
https://www.unlockbase.com/faq/en/Q_47.html
Troubleshooting stanley bs16bs
This could be due to several reasons such as a faulty battery, a problem with the charger itself, or an issue with the connection between the charger and the battery. Here are some general steps you can take to troubleshoot this issue:
Check the Battery: Ensure that the battery you're trying to charge is not faulty. If possible, try charging a different battery with the same charger to see if the problem persists.
Check the Charger: Make sure the charger is functioning properly. If you have another charger, try using it to charge the battery.
Check the Connection: Ensure that the connections between the charger and the battery are secure and clean. Any dirt or corrosion could interfere with the charging process.
Reset the Charger: Unplug the charger, wait a few moments, and then plug it back in. This can sometimes resolve minor technical issues.
https://www.manua.ls/stanley/bc15bs/manual
If unresolved, you might contact Stanley customer support.
4/18/2024 3:05:03 PM •
Cell Phones
Answered
17 hours ago
I need the reset code for Cash Power 2000 prepaid electricity meter.
How do I reset my cash power meter?
Reset your meter by pressing I, BLUE or # button, this is needed to ensure the 2 parts of your meter initiate connection again. This action should reset your meter. Please note, this error is not a technical error and you should never insist a technician comes out for this.
4/17/2024 6:33:31 AM •
Cell Phones
Answered
2 days ago
