20 Most Recent
Dell Latitude D630 Laptop Computer PC Notebook Questions & Answers
Dell Latitude D630 freezes
Try a System Restore and select a restore date before your problems started.To get to the System Restore - Click on Start - All Programs - Accessories - System Tools - System Restore
Keep getting web page not displayed
Hi GL Marsden,
I will be glad to help you but I need more information about the issue. Request you to answer the below questions which might help me:
(1)Does this issue happen for all websites or any particular website?
(2)Have you tried using different browsers like Chrome, Internet Explorer, Firefox, etc. to check if the issues exists on that?
(3)Are you using a wired/ a wireless connection?
(4)Check if this connection works on a different computer as it could be an issue with the Internet.
(5)Also check if other internet connections work on this computer (if available).
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Google com
there are 2 screws on the bottom of the laptop that once removed will the hard drive to slide out. 2 more screws will release it from the plastic slide mount.
HOW TO RECOVER INTERNET EXPLORER ICON?
Hi Anonymous,
It is unfortunate that the Internet Explorer Icon is lost. You may want to use the below link and try following the steps mentioned in it to recover the Internet Explorer Icon:
http://bit.ly/1l1cAWK
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
How do i turn off content advisor
Hi Anonymous,
I am assuming you are using Internet Explorer browser on windows 7 operating system so you may try opening Internet Explorer, click tools, then Internet options and content tab. Now in content advisor check disable option.
However, if you are using a different browser or operating system do let me know.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
System cannot communicate with battery
If you purchased an aftermarket battery this might be a permanent problem. If it's the original Dell battery you could try updating the BIOS via the Dell Web site.
Display vertical lines
There is the hardware problem of your laptop the vertical display, or the screen/monitor.
Wont see projector
Connecting an External Monitor or Data Projector You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Pnpdeviceproblemcode 19
I would manually un-install, and then reboot so the system could re-install. Also do a complete system virus scan, just to be surethat a bug isn't operating.
Dell latitude d630 laptop drivers download
Go to dells official site and click on the drivers and downloads tab, the put in your service tag or click on one of the options on the right. That should lead you to the driver downloads you need.
Screen leaking sticky liquid
Yes...the liquid is toxic. LCD solution can be highly toxic and ought not be touched. I would definitely put it somewhere where your cats can't get close to it, and bring it to a repair shop.
