20 Most Recent Dell Inspiron 1318 Laptop Computer PC Notebook Questions & Answers
i have a error code 2000-0146. is there a solution to this besides replacing the hard drive. can data files be safed??
Dell Inspiron... | Answered on Sep 09, 2019
It is a electronic circuit board with lots of electronic components. It controls the entire computer.
Dell Inspiron... | Answered on Nov 02, 2015
this is just a suggestion not an appropriate answer
just try this!
try to unmount the battery from laptop and connect the battery, then mount the battery back to laptop
then leave the laptop goes off with out power then connect the adapter back to laptop and try to on normally.
Dell Inspiron... | Answered on Oct 08, 2014
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-1318-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Dell Inspiron... | Answered on Jul 12, 2014
If you do not have the Admin/login passwords no one does.
Dell Inspiron... | Answered on Nov 10, 2012
If you didn't set the Admin./logon passwords and have it. then no one does.
make sure that your image folder is valid,go to setting in your webcam software and check the image output folder,is it empty or is the folder not valid? if yes,choose a new folder or make a new one
Dell Inspiron... | Answered on Aug 24, 2012
unscrew your disk drive and step by step try to open your computer until you get to your cd drive and manually take those 2 cds out
If you laptop has the type of disk drive that actually comes out of it then you can use a butter knife and VERY GENTLY pry the drive out.
If your laptop has the type where the disk goes inside the computer you will need to first SHUT DOWN YOUR COMPUTER, then remove the bottom of your laptop. DO NOT TOUCH ANYTHING EXCEPT THE DISK.
Dell Inspiron... | Answered on Jun 06, 2012
well introduce them(just kidding)
check that the plug is seated on the adapter going into the laptop
otherwise, there may be an issue with plug, adaptor or the place it inserts
might need a new adapter not that expensive really
Dell Inspiron... | Answered on May 23, 2012
try another power supply, maybe thats your problem
Dell Inspiron... | Answered on May 07, 2012
the software that you are using now for seeing the out of the camera may be corrupted.(I think so)
just reinstall your web cam software for once
Dell Inspiron... | Answered on Dec 29, 2011
Your laptop may have a SATA hard drive.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Dell Inspiron... | Answered on Nov 13, 2011
Welcome to Fixya
Uninstalling and installing the driver should be able to Fix the problem is this is a software issue only. If you successfully used external mouse without getting any problem then the problem would be the touchpad itself.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Dell Inspiron... | Answered on Sep 11, 2011
It would appear that you have a broken connection on the power connector on the motherboard of the laptop or a broken wire on the AC adapter. Repair of the connector on the motherboard could run about $125-$150 at a trustworthy repair shop. AC adapter replacement may be $25 over EBay.
If this information was helpful, please give a high rating. Thanks.
Dell Inspiron... | Answered on Jul 23, 2011
from what it sounds like, you are looking at replacing one of two things. inside your screen is a backlight. depending on what type, (chemical tube or led, more often then not its a chemical tube they go quickly) number two item is your inverter. the inverter supplies the power to your backlight, usually located under the screen, attached to the metal frame of the screen(you have to remove the plastic framing) in other cases your inverter will be integrated into the motherboard, or it will be plugged into the motherboard. if its integrated, buy a new laptop as the motherboard will almost cost the same as the laptop. unless you want to risk damaging the screen to try and replace the backlight, i would go ahead and suggest looking up ebay for a inverter for your screen. you have no battery but you are plugged in directly. with this case i want to say its the inverter. but you need to know if its A) under the screen B) integrated C) on the mobo but not integrated. with A) you have a good chance of easily replacing it. with B) buy a new laptop. with C) you have to remove the faceplate with your plastic power button stuff and leds above the keyboard to access the keyboard screws. remove the keyboard and the inverter will be on the top left of the motherboard.
Dell Inspiron 1318 Laptop Computer   PC Notebook Logo
56 questions posted
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
describe wipe cmos dell inspiron 1318
  • Computers & Internet
