20 Most Recent Xerox Phaser 7760 Laser Printer Questions & Answers
Magenta atc sensor failure
sir how to fix
11/19/2020 11:56:45 AM • Xerox Phaser... • Answered on Nov 19, 2020
Reset phaser 7760
Hi Anonymous, Due to the fact you asked for help quite some time ago I suspect this problem might be sorted by now. If not use the www.Xerox.com website should be able to help. Regards.
6/15/2015 3:43:00 PM • Xerox Phaser... • Answered on Jun 15, 2015
0answers
0answers
The accumulator belt on my 7760 phaser is giving a past end of life message. How can I find out how many copies it has remaining?
Try printing the full status sheet. If you print out all the setting it should cover all the information you need to make your judgement. Good luck.
4/2/2015 9:37:51 PM • Xerox Phaser... • Answered on Apr 02, 2015
Fault code 004-350 marking device failure
Sorry, Phasers need more than one minute to reset. You need to turn off and unplug the printer for 30 minutes, then plug it back in and power it up. That might reset the printer.
1/2/2015 11:19:52 PM • Xerox Phaser... • Answered on Jan 02, 2015
How do i inset the reset chip for black toner?
buy a new cartrade of ur printer.. or maybe the toner of ur printer check the toner.. try to cleaning the contact of the chip.
8/18/2014 9:40:50 AM • Xerox Phaser... • Answered on Aug 18, 2014
Fault 004-350
Here is a link for the Phaser 7760 service manual: Xerox Phaser 7760 Service Manual 004-350 Marking Device Fail (Controller Video)
7/6/2014 8:24:31 PM • Xerox Phaser... • Answered on Jul 06, 2014
0answers
Cleaning
Do you mean internally? Remove the toner cartridge. Get yourself an air blaster or can of air and blow any dust and toner out of the printer that you can - using a small soft brush like a paintbrush can be handy too. Use a soft lint-free cloth to wipe the rest out. If you want to clean the rollers isopropanol is good, but avoid contact with skin and eyes etc. Use a hi-alcohol based glass cleaner and glass cloth for any glass bits you find in there (like the laser unit window) if you want to clean the outside you can get this anti-static foam cleaner stuff which does the job well.. use with a light grade plastic scouring pad for those stubborn stains.. enjoy!
8/25/2012 11:02:30 AM • Xerox Phaser... • Answered on Aug 25, 2012
2answers
I have a Xerox 7760 dn printer. It stays frozen
any error code show please send me details
6/18/2011 11:39:43 PM • Xerox Phaser... • Answered on Jun 18, 2011
How do i replace an accumulator belt on a Phaser
  1. Open the Front Cover.
  2. Release and move the IBT Cam Lever down.
  3. Open the Right Side Door.
  4. Removing the IBT Belt Assembly
  5. Lift the Accumulator Belt Locking Level and pull the Assembly out to remove.
  6. Use Handle to transport IBT Unit. Protect the IBT Belt Assembly from
  7. On the front, there will be 2 torx screws on a plastic strip. Remove those and the cleaning assembly.
  8. There are 2 spring loaded clips. One on front and one on back that release the spring tension on the roller. You have to press them in and press the locking tabs.
  9. Then go around the frame and remove the screws in order to "fold" the assembly and remove the belt.
  10. Be very careful not to bend the bracket near the bearings or you will have belt tracking faults after replacement.
  11. Be sure you install the belt in the correct direction. There is a silver patch on the belt that must be on the inside of the belt assembly when installing. Look at the old one before removing to determine the orientation of the belt.
1/14/2010 8:19:11 PM • Xerox Phaser... • Answered on Jan 14, 2010
No printing cyan color
ink carteridge nosel jamed
10/16/2009 2:04:48 PM • Xerox Phaser... • Answered on Oct 16, 2009
Xerox Phaser 7760 Laser Printer Logo
Popular Tags
37 questions posted
Top Xerox Office Equipment & Supplies Experts
Ekse
Mehandi Husain ...
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Phaser Xerox
  • Phaser Xerox
Most Popular Question
xerox 7760 dn printer stays frozen
  • Office Equipment & Supplies
