20 Most Recent
eMachines T3656 Celeron 440 1GB DDR2 160GB Intel GMA 950 Windows Vista Home Basic PC Desktop Questions & Answers
I instal windows Vista, but
Download the Chipset driver on eMachines Website.
eMachines T3656 Driver Download
Select Product Family: Desktop
Select product Line: T Series
Select Product: T3656
Operating System: Select the version of your OS
Click on the Driver Tab
Download and Install the Chipset Driver
Thanks for using Fixya
Upgrade intel chip to what
What do you mean? Do you want to know what CPUs are supported by the board in order to select an upgrade or what?
EMachine W3507, will not boot after adding 2GB of
Where they purchased as a working pair some motherboards will only accept working pairs>?Make sure RAM modules are of same brand and type try one ram module at a time in the working slot closest the cpu if both work individually they are not a working pair
USB STOPPED WORKING
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with post a reply
hope it helps
How can I fix Netflix's distorted sound?
not a netflix issue in fact most likely amount of memory needs to be increasedcheck mem this waystart buttoncontrol panelsystem iconshows memorylet us know results then step 2
How do i remove the
hi there,open up the side of your case(you may have to unscrew a few screws) and look fo it..
If you do not no what it looks like heres one:http://plone.lucidsolutions.co.nz/dvb/t/images/IMG-0323%20Quad%20Tuner%20Card%20in%20PC.JPG
Just press down on the latches on either side of it to ''unlock'' it frmo the pci board,then just simply lift it out(make sure that your monitor/Display cables are not plugged in at this point and that your pc is powered down)..Good luck and Please rate me
I deleted too much stuff off my 1g emachine
Hi ,
Unfortunaly , you can't . You need the install disc . You can retreive existing data by extracting the hdd from your desktop and connect it to a healthy computer . Format the HDD afterwards , put it back into the desktop and launch install disc .
How can i do a
This indicates you have no resident restore partition on your hard disk drive. The easiest way is to put your Windows OS CD in the PC and startup. It should ask if you want to start from CD. Say yes and follow the instructions. You may need to press F2 or 10 to change the bootup sequence to start from the CD if it doen not do it automatically.
Thanks
Worked fine last night, discovered it this morning
the beeping is coming from the cpu.
1 unplug pc
2 pull out ram chips
3 use an eraser to clean the gold, yes thats gold
what happens is the gold on the ram oxidizes and does not connect properly and can go bad but cleaning it with an eraser sometimes works. take a cpu that is working unplu it pull the ram and you will see the same thing your other pc is doing.
4 reinstall ram (correctly)
5 boot up cpu
6 please vote.
Computer froze up, won't load up just getting the
Two factors why you are getting that problem;
-- Operating System (windows is corrupt) or
-- installed memory is defective
..try to swap other memory on your computer or also try inserting your memory to other PC to determine if its working or not, if the problem still exist try to reformat your PC maybe its the Operating System is having the problems.
Memory is too low to play downloads
Two separate issues. Do you mean you don't have enough system memory? Look up the system requirements for the game your trying to play. You did not list what OS your using. If its XP, try increasing the Virtual Memory. You do this by right clicking on "My Computer" Go to "Advanced" In the "Performance Options" click on "Advanced" There you can increase your Virtual Memory. Also check and clean out your "Startup" by clicking on "Start" then "Run" Then type in the word msconfig
Then click ok. Go to the "Statup" tab and clean out what you do not need.
I was wondering why my computer doesn't respond
Hi
How will you remove the virus some viruses are not remove buy virus scanner only. The proper way to remove all viruses are to reformat you personal computer. You need to have a fresh copy of windows operating system. Reformat your computer just load a windows CD to your CD room drive.
