20 Most Recent
RCA HD56W58 56" HDTV Questions & Answers
TV is blurry and the
There is almost nothing that can be fixed by yourself if your not trained in high voltages and advanced circuitry now days. This sounds like it could be your color guns going bad or the power supply.
This set also has an issue with The tv convergence board,require 2 STK convergence ICS and some or all it resistors to replaced to solved the tv convergence picture problems.
Shows 3 screens all Different colors overlapping
This tv have a problems known as a convergence problems,it dead.The tv convergence board,require 2 STK convergence ICS and some or all it resistors to replaced to solved the tv convergence picture problems.The shop will,cost u $300-350 for parts and labors.
The tv turns on and the large circuit board just
Sounds like you have Bad FBT Flyback Transfomer
to be sure you need to remove back and see where arking is coming from? Mats Electronics has Parts for this TV.1-800-628-1118 Let me know if you need anymore help.
Set turned off by itself, power light flashes, and
HI, thank you for visit fixya.
Two possibles solutions:
1.--Horizontal capacitor is burn or blown.
Need be replace, located beside horizontal transistor ( .0082uf 2kv ).
Clean the aarea on the chassis.
2.-- Transformer fly back is burn, need be replace.
If you will work on this tv or any special technician will work on this tv, request for replace capacitor on power supply. Common problem too.
Any question. let me know ,please.
Thank you.
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.)
I hope this helps.
(One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI
copy and paste link for manual
https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
I Want code list for RCA 4- device universal remote
You need the TV codes not the remote ones. I would use the Remotes code search feature as the Sanyo has allot of codes and you may spend hours going through them.
Sanyo remote codes 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
Where is the fuse located on a rca flat screen tv
The fuse on an RCA flat screen TV is typically located on the power supply board near one of its corners. The power supply board is the board with an array of capacitors, resistors, and heat sinks on it . The fuse is a small cylindrical tube with metal caps and is relatively small compared to other components on the board . If you have never seen a circuit board before, finding the fuse may be tricky. You can consult the user manual for your TV if you need help locating the fuse .
TV Fuse Replacement Guide: Locating and Replacing Your TV Fuse - PointerClicker.com
Replacing the fuse should be done with caution, especially if it is soldered to the board, as errors could lead to costly damage. You can check if the fuse is blown visually or with a multimeter-like tool. If you are unsure about how to replace the fuse, it is best to seek professional help.
What is the code for remote control for RCA model# RT 1971-AC
Better idea
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Replacement Remote Control for RCA DETG160R ...
Amazon.com
https://www.amazon.com > Replacement-DETG160R-...
Replacement Remote Control for RCA DETG160R DETG190R RT1971-AC RLDED3932ARK LCD LED HDTV TV - ( Compatible Model: DETG160R ) ; Controller Type. Button Control.
US$32.99 · In stock
RCA RT1971AC Replacement Remote
Remotes.net
https://www.remotes.net > products > replacement-rem...
If your original RCA remote has died, been destroyed or lost, or has simply stopped working, this replacement RCA remote can be the solution to your problems.
US$34.90
RCA Universal Remote Codes:
- The TV codes are: 000, 006, 011, 019, 027, 034, 038 and 044.
- The VCR codes are: 000, 005, 007, 008, 028 035, 037, 054 and 069.
- The cable box codes are: 000 and 027.
Apr 26, 2023
