20 Most Recent Polaroid m737t Digital Camera Questions & Answers
There are only three reasons photos look blurry: poor focus, shaking the cameral during the shot, or trying to take a photo of a fast-moving subject with a slow-speed camera.
You can usually see focus problems on the display before you take the picture, so that doesn't appear to be your issue. On the other hand, movement of camera or subject happens during the shot, so you'll only see that in the completed photo.
Camera movement first. Many cameras today have built-in "anti-shake" circuits that sense when you're the problem -- you're moving the camera during the shot. The best ones are very good at eliminating shakiness, but even they can't overcome large movement, as when you mash down the button to take the picture. If yours doesn't have anti-shake, or it isn't very well implemented, you'll just have to practice pushing gently on the button and holding the camera very still until it finishes the shot.
As for subject movement -- well, more sophisticated cameras offer ways to capture kids bouncing on a trampoline with a minimum of blurriness, but it's always going to be a problem.
If you don't want to switch to one of the more sophisticated cameras from a major brand, practice holding the camera steady during every shot and avoid shooting fast-moving subjects.
Polaroid m737t... | Answered on Jun 20, 2014
Consider NOT using the USB connection.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Even if you have to buy a card reader, it won't cost much more than a USB cable.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Polaroid m737t... | Answered on Jun 08, 2012
You don't need any software in order to use your camera.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program, such as Picasa.
Polaroid m737t... | Answered on Mar 18, 2012
You cannot charge this camera through a USB cable, you need to use the battery charger that comes with it. If they didn't give you a separate charger, you need to call Polaroid and order a new one, but be prepared to pay almost $30.
Polaroid m737t... | Answered on Sep 07, 2011
did you ever find a manual for your camera? I have a used one i can sell you really cheap if you still need one.
I AM LOOKING FOR A BATTERY CHARGER FOR A M737T POLAROID DIGITAL CAMERA. I AM NEEDING TO KNOW WERE I CAN FIND ONE PLEASE
THANKS
ANGELA WALKER
Polaroid m737t... | Answered on Dec 27, 2010
Take a look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Polaroid m737t... | Answered on Nov 29, 2010
Probably the first thing to try is formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible.
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Polaroid m737t... | Answered on Nov 05, 2010
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Polaroid m737t... | Answered on Oct 10, 2010
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Polaroid m737t... | Answered on Sep 10, 2010
Hello
Download THIS.
Download this free tool and run it on you card and it should be able to recover all pictures provided that you have not used the card since formatting. I recommend using a card reader for this.
After downloading and running (no installation required) , simply select deep scan and your memory card and it will start scanning, To recover a found file , right click it and select save.
Please note that the file names will probably not be available and also that some of the properties of the photo like date taken could be lost.
Please let me know when you have recovered your pictures safely or contact me if you need further assistance.
Regards
Andrea
Polaroid m737t... | Answered on Sep 03, 2010
battery could be defective or the charger doesnt work properly
Polaroid m737t... | Answered on Aug 16, 2010
The gear is worn or has sand or grit on the teeth causing it to not open up without resistance.
I would contact Polaroid directly regarding this issue to see if it is repairable economically:
http://www.polaroid.com/contact
Polaroid m737t... | Answered on Aug 06, 2010
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may require professional repair.
Polaroid m737t... | Answered on Feb 23, 2010
Hi there.
It might be a total loss. If the polarity on the 10 volt charger was also wrong, you might be lucky, but I don't think so.
Iceman.
Polaroid m737t... | Answered on Nov 10, 2009
check inside the battery compartment. mine did the same thing i check and the middle battery contact had fallen out
Polaroid m737t... | Answered on Nov 06, 2009
HI,
Here is a link to a page where you can download the user manual. Click on the link on the left side of the pages that says I want to download the user manual. It shows a little guy with a big stack of papers next to him. You can also use the option to have the manual emailed to you for a nominal cost.
Best wishes.
http://safemanuals.com/user-guide-instructions-owner-manual/POLAROID/M737T-_E
Polaroid m737t... | Answered on Oct 27, 2009
Polaroid m737t Digital Camera Logo
29 questions posted
Top Polaroid Cameras Experts
Ekse
Marvin
Marvin
LP
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
View Most Popular
Polaroid Cameras
  • Polaroid Cameras
Most Popular Question
wher buy usb cable polaroid m737t
  • Cameras
