20 Most Recent Microsoft Xbox 360 White Console Questions & Answers
My two cents should have stopped when you notice the blown caps. Then by pushing out the pads you went from dead to worse. If you post pics then we identify another spot to solder I'm afraid your soldering skill won't be up to par. But let's say your good and pull that off you still don't know that the xclamp will addressed the root cause. It might still of needed reflow/reballed or the the hana chip went bad or who knows. In laymans terms motor is shot, transmission gone i wouldn't waste money fixing the fuel pump. my advice is buy a new one and spend that time installing a xkey to save your dvd drive. Pro tip save the old dvd drive to make legal backups of your games.
Microsoft Xbox... | Answered on Sep 01, 2015
Yes, this can be tricky sometimes.
Be close to your console when synching your controllers. As always make sure the controller is on.
You will need to press both the synch button on the console and on the controller approximately the same time. If you have done this correctly. The controllers should have synched to the console in a few seconds.
Here is a link to show you how to do it for the Xbox 360.
Connect controller to your Xbox 360
To synch a Xbox One Controller go to link below here.
Connect wireless Xbox One controller to your console
Also just in case the light is flashing the and the controller is already synched, that means the battery is low and you need to change it out for new batteries.
Hope this has helped and good luck.
Microsoft Xbox... | Answered on Jan 15, 2015
My only guess would be that you disconnected the cable to the sensor while cleaning your Xbox. Have you checked all the connections before reassembling it? Check out the video I linked, maybe it'll help you!
Microsoft Xbox... | Answered on Jan 13, 2015
Let the Xbox update itself, when the update is done, you will be sent to the Dashboard. :)
But, try to update it via Internet (Xbox Live)
Microsoft Xbox... | Answered on Jan 14, 2013
Hi there baker19901
What to do when your Xbox Has problems with reading disks and you have tried cleaning the disk.
This does not mean your Disk Drive needs replacing more often than not it just needs the laser to be readjusted.
Option 1
You can send this off to Microsoft if your still in warranty because it is included in there free fixes so they will do the collecting for you, fix it and return the Xbox to you, all for free, but it will take 4-6 weeks.
Option 2
If you are out of warranty its the same process as above but its $130 in cost
Option 3
now a new Disk drive would cost around $75 for a compatible one and you may need some one to fit it at a cost as well.
Option 4
What I recommend is a XBOX REPAIR GUIDE that will show you the simple steps yourself, you will be up and running again in less than an hour and the cost is far less than option 2 & 3
Good Luck
xboxrestore
Feel Free to leave me a comment if you need further assistance.
Microsoft Xbox... | Answered on Jun 01, 2011
Bring it in to your local game store. If there is a problem, they should replace it with another disc. Your disc may have been scratched on an area that has loading information on it.
Microsoft Xbox... | Answered on May 14, 2011
Try going to your console setting, system info, then press LT RT X Y LB RB X left and then down (on the D-Pad).
If that doesn't work, try calling microsoft at 1-800-4MY-XBOX (1-800-469-9269)
Microsoft Xbox... | Answered on May 06, 2011
If your Xbox 360 console is not reading disc, first check it this happen to multiple CD. Check if the disc has scratches on it. If not, clean the disc by wiping it with damp soft cloth from the center outward. (Note: Use distilled water). Also make sure that the disc that your playing is compatible with your console. Next step is to clear the cache by going to My Xbox > System settings > Memory > highlight the storage device and Press Y on your controller > Select Clear System Cache. Then try to play again the disc. If still same thing, disconnect the hard drive, memory units and controllers and then reconnect it again. Try to play again the disc. If the problem only occur in one disc, replace the disc. If this happens intermittently, you need to contact Xbox Support for the repair of your console.
If your console is still under warranty, I strongly suggest that you call them to have free repair. Here's their contact number (800) 4MY-XBOX or (800) 469-9269.
Microsoft Xbox... | Answered on Apr 02, 2011
Red light problem can be fixed! there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console...
click here to download repair guide
Microsoft Xbox... | Answered on Mar 26, 2011
Hithere Dustyroberts
Whatto do when your xbox Has problems with flashing lights RROD/redrings of death.
Youwill need some simple repairs done on your XBOX as the GPU chip(Graphics) or the CPU chip (brain) or even both have lost connectionto the motherboard Due to overheating.
Option1
Youcan send this off to Microsoft if your still in warranty because itis included in there free fixes so they will do the collecting foryou, fix it and return the Xbox to you, all for free, but it willtake 4-6 weeks.
Option2
Ifyou are out of warranty its the same process as above but its $150 incost
Option3
WhatI recommend is a XBOXREPAIR GUIDE that will show you the simple steps yourself, youwill be up and running again in less than an hour and the cost is farless than option 2 & 3
GoodLuck
xboxrestore
FeelFree to leave me a comment if you need further assistance.
Microsoft Xbox... | Answered on Mar 25, 2011
it could be that u have to many of stuff on your ps3 or your ps3 is overheating
Microsoft Xbox... | Answered on Mar 21, 2011
hi, how well does your daughter look after her games? if her disk's have scratches on them the xbox will have trouble reading it and will often do this. another cause is that the xbox is old the laser will be worn out and will take ages to load a game.
the 2 solutions are:
1. check the disk, if it is highly scratched go get it cleaned, most gaming stores will do it for a small fee
2. take apart the xbox (only if out of warranty and step-by-step instructions can be found on youtube) and clean it gently with a duster
from lewis
portsmouth, UK
Gamestop, ebgames any video games retailler should have both refurbished hard drive and new for xbox
Microsoft Xbox... | Answered on Mar 14, 2011
Do other cd ,s work or just a certain one?
Microsoft Xbox... | Answered on Mar 13, 2011
thats signs of a red ring in the near future...unfortunately :/
Microsoft Xbox... | Answered on Mar 07, 2011
This is usually a precursor to your console receiving the "Red Rings of Death". However it could also just be a scratched disc.
You can also try to clear the harddrives cache
"a. Locate the System section of the Xbox 360 Dashboard. b. Select Memory, select Hard Drive, and then press Y to view the device options screen.c. On the Xbox 360 Controller, press the X button, press the X button again, press the left bumper, press the right bumper, press the X button, and then press the X button again.d. You will be prompted to confirm system maintenance, select Yes by pressing A."
Microsoft Xbox... | Answered on Mar 06, 2011
Does this happen with other games/servers? If so, it may be your network connection. Try resetting it.
If it's only happening with the EA server, you might want to call the EA Tech Support. This is their number: 650-628-4322
Good luck.
Microsoft Xbox... | Answered on Mar 01, 2011
connect the xbox to the internet.
If the console is within 3 years old it should still be under warranty. Call the Microsoft Xbox team at (800) 469-9269 to see if they'll repair it for you under warranty.
Microsoft Xbox... | Answered on Feb 28, 2011
Remove the hard drive from your xbox then start up your console. If the xbox loads up with the hard drive off then the drive has failed and will need replaced.
Microsoft Xbox... | Answered on Feb 19, 2011
Microsoft Xbox 360 White Console Logo
73 questions posted
Top Microsoft Video Game Consoles & Games Experts
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
Xbox Microsoft
  • Xbox Microsoft
Most Popular Question
xbox 360 motherboard question rrod
  • Video Game Consoles & Games
