20 Most Recent Samsung SGH 600 Cellular Phone Questions & Answers
To to connect your Samsung SGH 600 to your computer, you will need to go to the link below and download the software that meets your PC's specifications. (e.g Windows XP, Windows 7). Once the software is installed use a USB cable to connect your phone to your PC.http://www.samsung.com/uk/support/model/SGH-G600YKACNX-downloads
Samsung SGH 600... | Answered on Nov 27, 2012
Hello.
From your statement and the phone reaction of your phone to the command and in respect to my experience the reaction of your phone means that your phone have develop an internal problem from the mouth pies.
there are two ways of providing solution to the problem of your phone
1). you can get your self an external month pies from any of the phone store around your local area that will be compatible with the phone PLEASE make sure when getting the external month pies his same make with the phone i.e samsung make for easy compatible.
2) you will have to unscrew(open) the phone to do what is call troubleshooting or (service) on it you will have to get your self the basis tools for this phone to make this work easy.
the tool that is mostly common is call screwdriver (small side for for phone)
Carefully unscrew (ope)the phone from the point of the screws one after the other ,then remove the cae of the phone after you mot have remove all the screw around the phone carefully ,then hardly the phone panel with care clean the month pies surface carefully with cloth of soft brush or form PLEASE DO NOT APPLY ANY FOR OF LIQUID ON THE PANEL OF THE PHONE
the nature of this type of problem is whenever, the phone drop heavily
Please note if you can not carry out the instruction number two as do it your self offer then you can take it to any good phone work shop around your local area for helping hard in other to add to the problem.
Thanks.
Samsung SGH 600... | Answered on Sep 08, 2011
It is called PIN code. The PIN code is stored on your wireless service provider. Some service provider make PIN code 1234 as default. You may use this code, but if it not work, please get it on your service provider.
Regards
Samsung SGH 600... | Answered on May 09, 2011
take out sim power on input # * 7337 # phone resets then its done enjoy
Samsung SGH 600... | Answered on Aug 30, 2010
Hi Mr
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Samsung SGH 600... | Answered on Aug 27, 2010
    here is a detailed solution to help you out;
    1.Plug one end of the USB adapter into the phone, and the other end into an available USB port of your computer. Look to the bottom right of the screen and you should see an "Installing Driver..." window pop up. Wait a few minutes to allow the computer to look for a driver for your phone
    2.Look for a window to pop up that tells you "Driver was successfully installed." If it never comes up, or instead a window pops up that says "Driver was not successfully installed," it means your computer did not recognize your cell phone. In this case, you'll need to look for the driver. If it did install, skip ahead to Step 5.
    3.Install the driver by double-clicking on it. Before you do this, make sure your cell phone is unplugged. After you've installed the driver, plug in the cell phone, and it should be recognized
    4.Go to "My Computer." Look for a new drive that has either the brand/model of the cell phone in the name, or simply a picture of the cell phone on the drive. It will probably have the drive name F:, I: or G:. Double-click on it.
    5.
    Go to Start > File > Settings > Folder Options and select to enable hidden files and folders to be shown. Then go back to your cell phone's folder and look around. You should see a folder with the name "Pictures," "Photos," "images" or a similar name. Double-click on it, and you should see all your cell phone images.
    6.
    Select images and right-click "Copy." Then go to your desktop and create a new folder by right-clicking and selecting "New Folder." Open up this new folder, right-click and select "Paste." Your images will then be copied from the cell phone to your computer where you'll be able to access them any time.
    Take care.
    Samsung SGH 600... | Answered on Jun 25, 2010
    hello try restoring the phone to the default factory settings
    if this doesnt work, get a new battery
    Samsung SGH 600... | Answered on Mar 20, 2010
    Sometimes a deal is not such a good deal, it is an internal security setting that cannot be changed. If the internet is important to have on your phone you just might consider purchasing a new phone or get a FREE phone from this company, they have excellent customer service and offer all of the major carriers! Have fun looking!
    You may want to just purchase a new phone, I recommend this company they carry all of the major carriers and have excellent customer service, happy shopping! :)
    http://shop.acnwireless.com/mobile/?r=acn&eid=01958203
    Samsung SGH 600... | Answered on Sep 01, 2009
    sometimes if you dont turn the phone off for several days or long period the phone does search and will not allow you to use it so it must be shut off occasionally to avoid this
    Samsung SGH 600... | Answered on Aug 13, 2009
    T-Mobile USA and T-Mobile UK use different WAP and MMS settings - you will probably discover that t-zones doesn't work on the phone either.
    The simplest thing to do is go to the T-Mobile USA site and use the OTA configurator to send the correct settings for WAP and MMS to your phone.
    The link is here:
    http://tmobileuspublic.wdsglobal.com/phonefirst?countryId=37&bearerId=5&networkId=90&contractId=235&captchaEnabled=true&manufacturerId=35&step=phone.vm&selectManufacturerId=35&phoneId=1638
    Samsung SGH 600... | Answered on Jul 07, 2009
    Samsung SGH 600 Cellular Phone Logo
    Popular Tags
    36 questions posted
    Top Samsung Cell Phones Experts
    Muntejaya Ginting
    Muntejaya Ginting
    John Tripp
    John Tripp
    Michael Thomas
    Michael Thomas
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
    View Most Popular
    SGH Samsung
    • SGH Samsung
    Most Popular Question
    need unlock samsung g600
    • Cell Phones
