20 Most Recent Nokia 5000 Cellular Phone Questions & Answers
8answers
Security code to unlock my nokia 5000d-2
Des 15, 2009 - forgot my security code .. help me find it)) IMEI: 3548400224261860 / / /nokia 5000d-2
10/11/2023 3:53:48 PM • Nokia 5000... • Answered on Oct 11, 2023
2answers
Security code for nokia 5000d-2,type:362,imei:355701/01/02/142725/1
The default Nokia security code is 12345 unless it was changed.
10/10/2022 7:42:12 PM • Nokia 5000... • Answered on Oct 10, 2022
2answers
How to unlock restriction code
Restriction code is nothing but the unlocking for your mobile,
unlocking means in your phone just removes the SIM card restriction on your phone so that you can use any other network's SIM card.
To get the restriction code for your Nokia 5000 d-2 model mobile, just visit this site www.simpleunlocking.com/nokia-5000d-2/rs16wp9, in this site just give your IMEI number , country & network lock after that within a short period you can get the restriction code for your nokia mobile............I hope this may helpful to you.........
12/5/2017 2:56:41 AM • Nokia 5000... • Answered on Dec 05, 2017
SHOWING INVALID SIM
Just put SIM in another mobile phone and you'll get know the truth.
4/29/2017 7:33:11 AM • Nokia 5000... • Answered on Apr 29, 2017
11answers
5000d-2 unlock security code
MY MOBILE NOKIA 5000d-2 this mobile number lock activetd
but this mobile password code missing
serial no:324838029646143.
Type:RM-362
Code:0568255
imei no:354838/02/964614/3 PLEASE HELP SUPORTING PASSWORD
8/21/2015 2:44:16 PM • Nokia 5000... • Answered on Aug 21, 2015
Restart security code
Nokia 5000 Imei 352018045408222 Security code error help me
7/20/2015 9:10:19 AM • Nokia 5000... • Answered on Jul 20, 2015
My nokia 500 is been offline how can i change it to online mode
Check your sim card
7/9/2015 6:49:01 AM • Nokia 5000... • Answered on Jul 09, 2015
Recorded a conversation with abusive husband -
1st. when u are talking to him, go to options, then click record> (verizon phone only)
11/25/2014 8:04:29 AM • Nokia 5000... • Answered on Nov 25, 2014
2answers
Need master security code
Try to reset factory settings using UFSx or Jaf device..then it would be back to 12345 your default security code.
10/2/2014 6:08:42 AM • Nokia 5000... • Answered on Oct 02, 2014
On a nokia 5000 what is that place where it looks like a usb
Specifications : http://europe.nokia.com/find-products/devices/nokia-5000/specifications Picture: http://www.gsmarena.com/nokia_5000-pictures-2336.php It has a proprietary data connector between the Audio and Power Jacks, which is not USB - but exclusively for repair professionals to connect with. If you are a hacker - you may be able to find a model data link cable for this model. Best bet for an end user would be to connect to the PC using the Nokia Software tools via Blue Tooth: http://www.microsoft.com/en-ie/mobile/support/product-archive/?action=productArchive&tid=1871490&searchTerm=Nokia+5000
8/17/2014 1:15:48 AM • Nokia 5000... • Answered on Aug 17, 2014
I want to unlock my phone code de securite
try diz one bef9a6bf-5323-4f7c-9b12-2e52230488e2.jpg goodluck
7/6/2014 10:23:41 AM • Nokia 5000... • Answered on Jul 06, 2014
Securety code eror
check this one Master Code Generator will Instantly generate your Nokia's Master security code. This service can be used if you need to reset your Security Code. Your IMEI: 356924034968264 -- Your Nokia Master Code: 2401254345 or this one Nokia 5000 hard reset You can format your Nokia 5000 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345. If it is not working try this code: You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345. Some Nokia phone can be reset via this menu option Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YESRestore factory settings To restore the phone back to factory conditions, select Menu > Settings > Rest. factory sett. and from the following options: Restore settings only - to reset all preference settings without deleting any personal data Restore all - to reset all preference settings and delete all personal data, such as contacts, messages, media files and activation keys IMPORTANT! Formatting the device will permanently erase all user data and settings as well as add-on applications and operator specific settings goodluck
7/5/2014 9:32:16 AM • Nokia 5000... • Answered on Jul 05, 2014
I forgot my security code
try this hard format >>>>> At the standby screen type the code: *#7370# or hold down the following 3 buttons when you first switch the handset on: [Green, pick up call] + [3, def] + [*+] Be warned this will delete all information on the handset and return the handset to a 'fresh out of the box' state. All contacts, installed applications, calender entries etc will be lost. If you want a soft reset then there is another code: *#7780# This code will rewrite a few system files but doesn't peform a full format like the other two codes above. *EDIT* Make sure you have a full battery when reformatting a phone.
7/4/2014 6:48:20 AM • Nokia 5000... • Answered on Jul 04, 2014
0answers
Ephone unlock
Be the first to answer 5/5/2014 3:10:45 PM • Nokia 5000... • Posted on May 05, 2014Be the first to answer
0answers
I have nokia 5000d-2 the imei number is :
Nokia 5000d-2 phone restricted code
4/21/2014 7:42:51 PM • Nokia 5000... • Answered on Apr 21, 2014
3answers
My mobil is lock model5000d-2
Is it Your Phone Locked To Network Or Security Lock,It locked to Network means You cannot use with Other Network Sim card,You can find that By inserting Other Network Sim card.....It accepts means It's Unlocked from Network LOCK and You can use with any GSM Network,So it's Need some other LOCK unlock,If it not accept Other NETWORK Sim card in the Phone While insterting Other Network Sim card means ..It's Under Network Lock,You have to Unlock it Get the Unlock code and instructions from here
Mobileunlocksolutions.com and Unlock it from Network Lock ,then use with any GSM Network Sim card.....You can Try 0000 or 1234 as default code to Unlock from Security or Password lock,It not works means call the service provider get the master reset code and reset from Security Lock.You can follow the instructions Below To UNLOCK from Network Lock,You need to specify the Network and Country It locked now,to get the code...
Warning : Do not enter any wrong unlock codes on your Nokia 5000d-2 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5000d-2 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5000d-2 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5000d-2.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5000d-2 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5000d-2 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5000d-2
Each Nokia 5000d-2 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 5000d-2 mobile phone using the form above.
4/21/2014 7:37:42 PM • Nokia 5000... • Answered on Apr 21, 2014
Security code nokia 5000d -2 IMEI 356924036828813
Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
4/21/2014 6:59:22 PM • Nokia 5000... • Answered on Apr 21, 2014
287 questions posted
Popular Products
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
View Most Popular
Nokia Cell Phones
  • Nokia Cell Phones
Most Popular Question
5000d 2 unlock security code
  • Cell Phones
